Guys i have a 92 f350 dually i want to redo in the interior it has bench seats front and back, can anyone tell me what seats besides the centurion that will fit? like from any Bronco and the years, just getting started on this project any help is plenty.
Any front seats from a 92-96 F150-F350 will work, and the Bronco of those years. I would imagine the earlier years from 81 up would also fit, but not 100% sure on that. I doubt Ford changed the bolt pattern of those trucks.
I believe interior seat wise crew cabs can only take 80-96 regular cabs or crew cabs to fit with out modifying.
I believe it is broncos and super cabs that go together but not sure. I personally modified super cab seats to fit in a regular cab but I will never do it again.
Trav
Trav
Correct.
Crew cab trucks use the same seat as a regular cab for the front and rear positions.
I will third this.
You can use ANY bench seat from 1980-96 and 97HD f250/f350
You can also use the 40-20-40 seats from the 94-96 and 97HDF250/f350 as long as they came from a reg cab or crew cab (SUPERCAB or bronco WILL NOT WORK)
