Big Block FE '83 Bronco Buildup - Page 2 - Ford Truck Enthusiasts Forums
Old 02-17-2014, 09:43 PM
Bubba Jones's Avatar
Bubba Jones Bubba Jones is offline
Bubba Jones has a good reputation on FTE.Bubba Jones has a good reputation on FTE.Bubba Jones has a good reputation on FTE.
You're starting to pile up a whole bunch of extra broncos! Is that three you have now? Obviously two of them are just for parts, but that's a lot of hauling around.
I would love to take some wrecked trucks/cars for parts or to fix up. I need my own place for that though.. and I need to get out of college!!! I've been in too long.. hopefully I'll get out soon enough and pass all my classes.
Old 02-17-2014, 11:09 PM
1985 Bronco's Avatar
1985 Bronco 1985 Bronco is offline
1985 Bronco is starting off with a positive reputation.
Do you still have the old green rims?
Old 02-18-2014, 01:30 AM
EffunFiddy's Avatar
EffunFiddy EffunFiddy is offline
EffunFiddy has a good reputation on FTE.EffunFiddy has a good reputation on FTE.
That thing is gonna be bad a$$! Subscribed. I spy a pair of stepside fenders hanging on the wall too. I'd trade a boatload of Bronco parts for those if you were closer to home haha
Old 02-18-2014, 02:51 AM
'86 F150's Avatar
'86 F150 '86 F150 is offline
'86 F150 is gaining momentum as a positive member of FTE.'86 F150 is gaining momentum as a positive member of FTE.
No just the grey one and the white one. The one my brother just got is a short box. Might be building this one too.
Quote:
Yes, still got em. They are really dry rotted and going bald. I stripped the paint off them. They were chrome. They have some rust but still looks better then lime green/black. Going to save them for trips to the sand dunes.
Quote:
Thanks. That stepside stuff might go on the frame my brother just got. I have the box and tailgate too but they need some rust repair.
Old 02-18-2014, 08:57 PM
peganit2's Avatar
peganit2 peganit2 is offline
peganit2 is starting off with a positive reputation.
Hit a balmy 35 degrees here!
Did you jump all over the chance?
Old 02-18-2014, 09:39 PM
'86 F150's Avatar
About the same up here. Didn't have a chance, had to snowblow the 10-12 inches of snow we got last night. Couple hours worth of work. Planning on working on it tomorrow. Supposed to be 36 degrees.
Old 02-18-2014, 11:15 PM
I believe I have the same rims, but mine are painted black. Where did your buddy get them? I need to buy a spare for my truck.
Old 02-19-2014, 02:44 AM
'86 F150's Avatar
I think they were on it when he bought it. Summit Racing has a similar if not the same ones in chrome starting at $63.97. They are called Super Trucker Wheels made by bart wheels. They also have a US wheel 044 brand black rims that are similar too and start at $59.97. Summit also has there brand of rims too called Summit Racing 85 8 and starts at $46.97.
Old 02-19-2014, 05:14 PM
peganit2's Avatar
40's now
Heat wave!
Old 02-20-2014, 04:09 PM
'86 F150's Avatar
40's now
Heat wave!
Yeah, it was about 45 here. Got a little work done on it last night.
Old 02-20-2014, 04:52 PM
'86 F150's Avatar
Here are the headers that came off the FE
Had to take the vent panel off to unplug the speaker to take off the door and the cowl is loaded with mud. Gotta get that crap out of there.
Took the door off and started wire wheeling the paint and rust off with a angle grinder. Rocker is in good shape.
Some better pics of the side before I tore it apart. Tires don't stick out too far past the fenders. Thinking about moving the rearend back a little to center it in the wheel wells.
Old 02-20-2014, 06:29 PM
I would replace the quarter panels before you move the rear end, so you know exactly how it looks.
  #28
Old 02-21-2014, 10:47 AM
'86 F150's Avatar
Yeah definitely. Also going to swap out the rear springs for some with some arch.
  #29
Old 02-21-2014, 11:48 AM
You've got a lot of work done! It would be nice to have a garage like yours.. The weather is really nice out here so I don't need to work in a garage now.. but during the summer it gets pretty hot..
Maybe a dumb question but, I've never removed/installed a rear end but have future plans of getting dana 60s on (when I go diesel after my newly freshened motor goes). Whats involved in you moving the rear end back? Are you going to have to weld in a new spot for the mounting brackets on the axle to go? Or can you just bolt them further back? I'm just curious because when I take my axles off in like 5 years I'll want to know what I'm doing.
  #30
Old 02-21-2014, 02:11 PM
'86 F150's Avatar
Wish the garage was heated for winter use. I'd be out there more. If I move the rear end I will torch the rivets on all the mounts and move everything back the amount needed to center it and get a drive shaft spacer to make up the difference.
Howdy from Texas! Need help ID'ing this truck sharp21 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-20-2016 06:11 AM
New project: '83 F100 XL '86 F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 08-03-2015 10:09 AM
Todays aftermarket add on.... jonrjen 6.7L Power Stroke Diesel 10 05-21-2015 07:26 PM
Winch set up finally in place and working just fine jonrjen 1999 to 2016 Super Duty 13 04-05-2015 10:39 PM
Bodiak front hitch with a Ranch Hand Grille Guard is a GO!!! jonrjen 6.7L Power Stroke Diesel 10 03-12-2015 09:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
