Power steering pully alignment - Ford Truck Enthusiasts Forums
Old 02-14-2014, 10:01 AM
SC'79 SC'79 is offline
SC'79 is starting off with a positive reputation.
I woke up, got in the car to work today, cranked up the truck and pop- there goes my 3 month old power steering/fan belt. 1979 f150 with 460 non ac. I got a new belt and after looking at it closer, the power steering pulley is almost, but not completely aligned with the other pulleys. The side closer to the fan is toward the engine 1/8 of an inch or so, just visible. The broken belt was heavily worn on the bumper side where it contacted the side of the pulley more. How is this re-aligned? I'll try and get some pictures.
Old 02-14-2014, 10:12 AM
51fordf5's Avatar
51fordf5 51fordf5 is offline
51fordf5 is starting off with a positive reputation.
It sounds like either the pulley itself it bent, or the pump shaft is bent/has play in it. I would take the belt off, spin the pulley by hand and watch the shaft. If the shaft moves around, you need a new power steering pump. If it doesn't, your pulley is bent and you'll need a new one of those. In either case, you will have to remove the pulley. You NEED the proper puller for this. If you go in to your auto parts place and ask for a power steering pump pulley puller, they'll know what you're talking about. It's usually free to rent too
Old 02-14-2014, 10:29 AM
turbohunter's Avatar
turbohunter turbohunter is online now
turbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant future
Is the pump original or has it been replaced?
If it has been replaced then who ever did it may have driven the pulley on to far. It is a press fit.
If your pump is ok you can use the puller to slide the pulley to the correct position.
But as mentioned above you need a specific puller.
Old 02-14-2014, 11:18 AM
Not sure if it is original or not, I have not replaced it. the pulley does not wobble or doesnt appear bent, or the shaft, but it seems as though the bracket is not allowing the pump to align property. Could I put a washer or two on the left side (looking at the engine) of the bracket to push that side out enough to let the pulley align?
This is what my bracket looks like. I'm talking about washers under the 2 screws on the left?
Old 02-14-2014, 12:16 PM
hickory1991 hickory1991 is offline
hickory1991 is gaining momentum as a positive member of FTE.
If pump pulley and shaft look ok, then shimming with washers or preferably spacers is done to align pulley with the other ones.
Old 02-14-2014, 02:52 PM
Jklnhyd's Avatar
Jklnhyd Jklnhyd is offline
Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.
Just get the puller and back it off 1/8", much better than washers and all that. And if you go too far, use a socket that is bigger than the shaft, and a hammer, and tap it until its aligned
Old 02-14-2014, 03:13 PM
Can't see your pics but if all is ok and it was me, I'd get the puller and back the pulley off till the belt lined up.
If you go to far, there are threads inside the shaft that you can put a bolt into with a nut and washer on it to press the pulley back on a bit. If you catch my drift.
Old 02-14-2014, 03:54 PM
EricJ EricJ is offline
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
I think he is saying it's not straight with the crank, not that it isn't aligned properly. Sounds like the bracket may be bent, in which case shiming one side is a good idea.
Old 02-14-2014, 04:09 PM
EricJ's got it. I havent had a chance to run out and grab some pictures yet. I'll shim and see what happens. Thanks guys
Old 02-14-2014, 07:50 PM
Quote:
Oops, didn't get that from the post.
Seems odd the shaft would be bent. Sounds more like the pulley, they bend easy.
If it's the shaft then remove and replace.
If it's the pulley they are pretty easy to straighten if not to bad.
If it's the bracket, I would just straighten it or find a replacement.
Old 02-18-2014, 09:27 PM
Jklnhyd's Avatar
Oddly enough, mine is not aligned correctly either....
Mine needs to be shimmed out on the right, im not totally sure how much, guessing 3/16"-1/4"
Old 02-19-2014, 09:09 AM
Well I went through 4 fan belts in 3 days, and no matter what I could do i couldnt get them to line up. Took it to a mechanic friend and found not only was the bracket bent, but also one of the threads to the block was completely stripped out so he re-tapped it and shimmed accordingly after straightening out the bracket as much as possible. Almost perfect alignment now, as close as we're going to get. Been almost a week on the same belt so thats great. Good thing for Gates belts warranty, only bought 1 and got free exchanges for a new one when it would break from oriellys.
Old 02-19-2014, 10:13 AM
Jklnhyd's Avatar
I have to go out and pull my pump today. My bracket looks fine, and if i shim out the right side, it seems like it may make it worse. I am going to take a look at shimming the pump in the bracket that hooks to the engine bracket, the one that slides on the engine bracket. Makes no sense why its off like this
Old 02-19-2014, 10:21 AM
Here is how mine looked before hand. Will get some after pictures as well.
Old 02-19-2014, 10:38 AM
Jklnhyd's Avatar
Shouldnt the belt be on the other fan pulley? I only have 1 groove for a belt on mine, and it apears to line up with the other one
Belts for 300 I-6? What year do I have? 86stepsideF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-27-2016 11:39 PM
Serpantine belt jumps off fuelhog450 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 04-13-2013 03:58 PM
F150 belt issue greasemanicure 1987 - 1996 F150 & Larger F-Series Trucks 6 03-27-2012 11:03 PM
Fan Belt Squeal 460Runner Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 08-21-2011 10:48 PM
bent belt tensioner MAS96F150 1987 - 1996 F150 & Larger F-Series Trucks 4 08-24-2010 11:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
