performance issues - Ford Truck Enthusiasts Forums
performance issues
Old 02-14-2014, 09:45 AM
Fordgrl83 Fordgrl83 is offline
Fordgrl83 is starting off with a positive reputation.
performance issues
I have a 2001 Ford F150 5.4 ltr 4x4. / My truck was running great. Replaced the fuel filter and it was an avalanche. She wouldn't run above 15 mph and wouldnt turn over. Acted like she wasn't getting enough gas. Running better now but not where she was. She bogs down acts like she wants to stall out or misfire but she's not sure which if you step on the gas to hard.
These are the parts that I have changed in the year and a half I've had the truck and how long ago they were changed
Intake manifold - 6 months
Spark plugs - 6 months
Ignition coil packs - 6 months
Upper and lower radiator hoses - 6 months
Fuel filter - last week
Idle air control sensor - 5 days
4 O2 sensors - 5 days
Vacuum hoses - 5 days
Mass air flow sensor - 5 days
Fuel pump - 4 days
Fuel lines- 4 days
Fuel regulator - 1 day
I have the throttle positioning sensor
Left to replace.
Old 02-14-2014, 09:48 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Are there any DTC's showing? Have you done a DTC scan yet?
Old 02-14-2014, 11:16 AM
performance issues
Not since I had the O2 sensors done.
Old 02-14-2014, 02:05 PM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
Have you checked the fuel pressure running at the rail?
Old 02-14-2014, 04:19 PM
I have and I replaced the fuel regulator. I changed vacuum hoses near my egr valve also one was collapsed and another had a knife cut in it which makes makes me wonder because I had it in the shop for the o2 sensors and they kept trying to get me to let them do more more...
Old 02-14-2014, 10:04 PM
clogged cat?
Old 02-15-2014, 02:56 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Fuel filter in backwards.
Old 02-15-2014, 02:59 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
^^^ that was my first thought too
01 Explorer Sport - engine randomly stalled and now won't run right changetheworld Explorer, Sport Trac, Mountaineer & Aviator 1 09-09-2015 06:02 PM
05 5.4 runs very rough jcrook85 2004 - 2008 F150 4 03-07-2015 03:40 PM
94 Explorer with wierd problem Redneckfordf2502002 Explorer, Sport Trac, Mountaineer & Aviator 10 06-13-2014 10:20 AM
Misfire in cylinder 5 (P0305) '06 Expedition EB 5.4 3v 83frankenstein250 1997-2006 Expedition & Navigator 10 06-07-2014 07:40 PM
No Start...Need Help bigbeariron 6.0L Power Stroke Diesel 47 01-21-2012 06:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
