1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
f350 5.4 no start no crank nonpower
Old 02-13-2014, 11:37 PM
jwiowa's Avatar
jwiowa
jwiowa is offline
Having an issue with my 04. Wife got in the truck to move it and no dome lights no crank nothing. Swapped the battery for a new one. Still nothing.
i checked all fuses.
I literally was just driving it 10 mons prior to her getting in it. Said dome came on for a second then shut off.
Any ideas???
Thanks
In advance!
Old 02-14-2014, 06:24 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Bad battery cable or their connectios. Get out the multimeter and check them.
Old 02-14-2014, 08:40 AM
BigOl04's Avatar
BigOl04
BigOl04 is offline
check cable ends (terminals/grounds) for corrosion and very power at the fuse panel.... do you live in a colder climate and or moist climate.. the back sides of the fuse panels can corrode and cause this issue... Just my .02
Old 02-14-2014, 08:46 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
this will be a good read....keep us posted. would be good to know if the battery involved is fully charge.....google battery state of charge test...you basically disconnect the battery and get the at rest volts. if the battery is fully charged...you can focus trobule shooting else where.
fosterinwy
01-24-2022 08:02 PM
Caleb H
01-29-2018 08:09 AM
Michelle Abernathy
2004 - 2008 F150
10-09-2015 07:27 PM
BruceJeremy
1997 - 2003 F150
02-26-2012 05:39 PM
lumberguy
12-10-2002 01:25 PM
Quick Reply: f350 5.4 no start no crank nonpower
