Transmission problem
02-13-2014, 11:07 PM
on
2007 Expy EL EB 4WD 156,000 miles.
Today I noticed the Transmission seems to be stuck in 3rd or 4th gear and won't up or down shift. Goes int neutral or Park ok. Wrench icon is on.
Any suggestions?
02-14-2014, 11:39 AM
Take it to a dealer or mechanic you trust? If you have a friend with a code scanner you can try that, but it's more than likely you can't shadetree mechanic it if the trans needs to be opened.
02-15-2014, 07:23 PM
on
Wrench icon means problems with drive by wire system. I think. It will lock vehicle in limp mode. Defaulting in only one gear.
Sent from my Z10 using IB AutoGroup
02-20-2014, 02:46 PM
on
Definitely sounds like it's in limp mode. Lots of things to put it there. At minimum I'd suggest check the fluid level. Other than that see if any codes are thrown.
02-20-2014, 02:47 PM
on
02-24-2014, 11:31 PM
on
It was a cracked electrical connector sleeve going into the bulkhead of the trans. Must be a common problem since Ford dealer had the parts in stock.
Slimmy2600
09-10-2014 08:05 AM
bob0312
04-16-2010 02:25 PM
lccpondguy
02-04-2009 11:40 AM
jessman1128
03-13-2005 11:29 PM
jethro
07-04-2001 11:14 AM
