coolant flush and fill - Ford Truck Enthusiasts Forums
Old 02-13-2014, 08:31 PM
pony pony is offline
pony is starting off with a positive reputation.
I'm wondering. I only put about 4000 miles a year on my '02 f250 with the 5.4 and manual trans. Owners manual says change the anti freeze every 3 years. Considering the amount driven is this "over kill". How often would you change it. Has the coolant had it because of the time in service? ( I have it done at the dealer with Ford coolant.)
Old 02-21-2014, 06:05 PM
orbust orbust is offline
orbust is starting off with a positive reputation.
whether its used or not coolant has a shelf life. So ten year old coolant still in the original bottle is more or less worthless in comparison to new coolant. You can test your coolant, but honestly the best/easiest method is simply a visual test.. if it looks clean and fresh you are probably good. If it looks nasty or discolored replace it. If it was a diesel on the other hand I would say replace it immediately without even looking at it and do it before the recommended interval... lol
Coolant Leak ka2rkv 6.7L Power Stroke Diesel 7 12-18-2015 08:18 AM
Coolant Change Questions LB_ 6.7L Power Stroke Diesel 9 12-16-2015 07:39 AM
2008 Expy coolant change amstel78 2007 - 2014 Expedition & Navigator 15 03-05-2014 08:25 PM
Thoughts on coolant caps Iaff113 6.0L Power Stroke Diesel 6 02-15-2014 11:56 AM
coolant change interval? freefam 1999 - 2003 7.3L Power Stroke Diesel 2 08-26-2003 08:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
