292 vs 302, and value of 292 - Ford Truck Enthusiasts Forums
Old 02-13-2014, 02:43 PM
MCD46 MCD46 is offline
MCD46 is starting off with a positive reputation.
I am trying to figure out which direction to go with my 64, and motor and trans is a big debate. For those of you who have swapped in a 302, can you give me your insight on pros and cons of the two motors?
Originally I was thinking of keeping the 292, but in my searches it looks like a basic crate 302 is around $2500. My guess is with parts and machine shop for rebuilding the 292, I would be at least $1500-$2000. I would like to have the access to performance parts availabilty of the 302, as well as the trans selection.
Other question is how desireable, and what value, is a used 292 and 3 on the tree trans? Would I be able to sell these for some profit if I swap? I dont need a garage decoration, that is for sure.
Thanks.
Old 02-13-2014, 05:32 PM
skidoorulz's Avatar
skidoorulz skidoorulz is offline
skidoorulz is starting off with a positive reputation.
There are performance parts available for the Y Block. In my opinion I say leave the 292 in it, but I am old fashioned. If you want to see what you can do to a Y Block I have a thread at slick60's website. It is under projects and builds titled 64 ford f100 restore I believe. Aluminumum intake holley 4 bbl finned valley cover finned valve covers headers bigger cam high comp pistons. It is all available, check it out.
Old 02-13-2014, 05:39 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
Realistically, what is your goal with the truck?
Don't forget the cost to swap the 302. That will add to the total cost of the 302. $2500 can get you a better than stock 292 and you don't have to swap and it will eat most 302s for lunch. However, if you are looking for serious power, the lower cost of the 302 may make it worthwhile; if you're looking for serious power, I'd strongly recommend something even larger. A 292 tends to get better mileage than a 302. The 292 has excellent torque for it's size and responds very well to the typical modifications that are applied to virtually every other engine to get better performance.
A used 292 and transmission is worth about $100 to maybe $600. This depends on the condition. If it runs and drives, you must be able to demonstrate that. Ran when parked means it doesn't run. You will not make any profit by selling them but it will help offset the cost if you do swap.
Old 02-14-2014, 03:59 AM
EricJ EricJ is online now
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
I vote 292 as well. Something about a motor that will idle so slow you can count the fan blades going by is just cool.
Old 02-14-2014, 04:21 AM
1958 Ford F250's Avatar
1958 Ford F250 1958 Ford F250 is offline
1958 Ford F250 is starting off with a positive reputation.
Thumbs up 292 Y BLOCK 4.8L :)
Hi 292 all the way... They are very reliable, strong, easy to find Parts & Easy to work on... I would Rebuild the 292 for sure before I get a crate Motor.. In my Humble Opinion
Old 02-14-2014, 04:30 AM
Quote:
OK, everyone is in agreement, Your NOT ALLOWED to buy a 302
Old 02-14-2014, 07:30 AM
C G B's Avatar
C G B C G B is offline
C G B is starting off with a positive reputation.
If going the SBF route, just go straight to a 351W.
That being said, the Y block is a cool motor. Its all in what you want to do.
Old 02-14-2014, 12:48 PM
I knew the 292 has a following, but didnt realize the vote would be this unanimous! Guess it is settled, keep the 292!
Honestly though, I do like the idea of the 292. It seems to be a good little motor, plus the nostalgia of having it in the truck. My concerns around it were the older technology, and the availability of parts, both for rebuild and performance. I guess I just have not found all the right places for parts yet.
A couple items on the rebuild. Are there upgraded gasket/seal kits that are preferred? What about the rear main, as I have heard, and am living the problem, that they tend to leak on the 292. I dont want to get done with a rebuild only to have a motor that develops leaks soon after.
Also, what options do I have for upgraded transmissions with the 292. I want to keep a manual shift, and have been eyeing the t-5 upgrade that is available. Is there anything else that I should consider, or is t-5 the way to go? I really would like to keep the manual trans in the truck.
Thanks to all for talking some sense into me! I guess I need to quit looking on summit, and start planning my build.
Old 02-14-2014, 03:42 PM
Re modern technology, the 302 and all Windsors are technically newer and, sure combustion chamber designs became better and roller cams and fuel injection were added at some point but the technology, at it's core, is the same. It's not leaps and bounds better. And for the early years, I would not argue that the small block is at all better. Don't get me wrong, the Windsor is proven to be a good motor and it has it's place.
Best Gasket probably make the most popular gaskets. A great source for Y parts is ford-y-block.com. Any 50 year old motor is bound to have issues which will probably include leaks. Y-Blocks don't tend to leak when they are fresh and proper. Further, there are many areas for the oil to leak and appear to be the rear main when it is not. They include but are not limited to: the valley pan, valve covers, oil pump, the studs in the rear main retainer, the cam plug, oil galley plugs, oil pan gasket, the bolt holes at the very back of the head on the intake flange.
The easiest manual transmission swap probably is the T5 simply because the parts to do it are readily available. Whether that is good for you depends on your goals. For street use, it will probably be just fine up to around 400hp or so. Our trucks don't have the traction and in many cases really aren't that heavy compared to the cars that t5s came in, to be a serious threat. For spirited street driving, racing, or more power, you may want to consider something like a t56 or tko but you will also have to figure out how to mount them.
For what it is worth, I know a couple people with 4 cylinder t5s behind some pretty stout Ys in trucks. One is a stroker, ported heads, etc and he used to haul a camper with it. The other is a turbocharged stroker that put (I'm too lazy to look it up right now) about 450hp to the ground. Both of these are drivers and both are going strong. Perhaps they will break eventually, I don't know, but if that is not a testament to the durability of a T5 in a street setting, I don't know what is. My T5 is a V8 version with over 10k miles so far, behind a stroked, ported, cammed, etc Y. It's a driver. I race it occasionally and it's not given me any trouble yet.
Old 02-14-2014, 10:13 PM
skidoorulz's Avatar
Quote:
I forgot to add, mine is bored 60 over so that makes it an almost 302
Old 02-15-2014, 05:11 AM
as long as it doesn't make it an almost 5-0 I'm fine with that
Old 02-15-2014, 09:58 AM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Everybody thinks parts are difficult to find for Y-blocks, they just aren't laying in the ditches easy. BFD.
Old 07-25-2014, 08:50 PM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
Surfing the site tonight I ran across this statement.
Quote:
I have to say that this gave me a good chuckle.
I have an Explorer 5.0 sitting in the garage that I traded for, I figure actual cost to me is $700.
The Explorer 5.0 with no headwork and no cam swap with headers, exhaust, duraspark ignition and a properly tuned 4V will leave all but a few 292s in the dust and at a much lower cost. There are a lot of dismantling/recycling yards that specialize in low mileage 5.0s Grab a couple while you can, they are going to run out of them in a few years.
If it were the other way around Ford would still be producing the 292.
Old 07-25-2014, 09:23 PM
An explorer 302 probably would make for a comparable engine. A roller cammed, fuel injected 302 is a great choice but pretty much any 302 up until those things happened is a dog.
Nobody is arguing about the cost. A Y-Block is more expensive. Though if you make it more apples to apples and rebuild that 302, the difference in cost does decrease. A good running used 292 would probably be as much or less than that used 302.
And you also have to factor in the cost of the swap. Any engine other than stock does you no good until it is installed properly and moves the truck safely. That takes time and/or money to achieve.
Old 09-12-2016, 08:08 PM
cliff tate cliff tate is offline
cliff tate is starting off with a positive reputation.
292/302
i am a die hard y block fan,and know them well.But the 302, even hp289 are superior to ys in every way.lighter ,narrow good trans sulection,2aluminum good heads afraction of the cost sir muftis light heads as well as readily avail. several years ago i had a 54f1 inst a roller 5ltr,headers inst winsor intake valves, alum. intake,new holley 600cfm carb,dura spark ign. 4spd od manual.performed very well and buned 30%less fuel cost under 2500 to build including the core.
this does not mean i will replace the 292 in my ranchero,or give up on the 292 swap into my 48 mere f47.but being retired i like the work and want some thing diferent.
my vote would before 289 and if funds avail a roller cam 5ltre.
i
292 or????? SIXTFOR 1961 - 1966 F-100 & Larger F-Series Trucks 40 09-24-2015 03:26 PM
Motor swap help gabescanlon 1961 - 1966 F-100 & Larger F-Series Trucks 3 05-26-2015 03:59 PM
T98 4spd swap? Gregxlt 1957 - 1960 F100 & Larger F-Series Trucks 15 02-20-2014 06:29 PM
how much compression out of a 292 59flatbedford Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 8 03-20-2007 05:33 PM
Just started rebuild 312 into a 292 Block. atticmole 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 12-10-2003 07:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
