Ignition Parts List - Ford Truck Enthusiasts Forums
Ignition Parts List
Old 02-13-2014, 02:34 PM
mmalz6 mmalz6 is offline
mmalz6 is starting off with a positive reputation.
Ignition Parts List
Hi, I am getting ready to ship my 1951 Flathead V8 and transmission out to be rebuilt. I am going to convert it over to 12 volt. Can anyone out there give me a list of other parts I will need? Example:
Starter
Distributor?
Generator?
Anodes?
Other?
I am not sure how these ignitions and wiring works on this truck. Also, is there a good manual that shows this type of information?
Mike
Old 02-17-2014, 11:32 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to all
In order to eliminate two sources of problems (points and condenser) I replaced both with a Pertronix ignitor. My truck ran great after I did that. The unit fits right inside your distributor and is easy to install and hooks up just like the points did to your coil, which you might want to replace too if the truck has not run for a while.
Amazon seems to have the best prices but you can check around:
<u>http://www.amazon.com/PerTronix-91281-Ignitor-Adaptive-Cylinder/dp/B000JUT7RS</u> http://www.amazon.com/PerTronix-91281-Ignitor-Adaptive-Cylinder/dp/B000JUT7RS
Your 6V starter will work fine. No need to replace it.
You have lots of choices on 12V power generation. I switched to a one wire alternator which fit right where the generator was located. I bought a Y bracket to make it easier to adjust. You probably have a wide belt (actually look at the grooves and not at the belt as someone may have put on a narrow belt by mistake. Also so you may need a wide pulley depending upon what your new alternator has. Just make sure that the pulley is the same size in diameter as the one that you take off. Too large and you may have a problem generating enough "juice" at idle. Stay away from the chrome alternators from Speedway as the chrome peels after a year or so.
Not sure what you mean by "Anodes"
Also take the top off your carb and check the bottom of the bowl. If it looks like what you see in the picture you will need to clean it our. Also remove the fuel pump bowl and clean it. And check the bottom of the tank and please use a flashlight not a match If it has junk in it you should remove the tank and send it out to be cleaned and checked for leaks. Many radiator shops will do that for you. Also flush all the lines.
That should be enough to get you started. Good luck,
Old 02-17-2014, 03:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Do a Google search on 12v conversions, you'll find hundreds of articles. A big part of it is the gauges, which still need 6v. To handle them, there are many different types of devices to reduce power down to 6v, among them "CVR's" (constant voltage regulators also sometimes called instrument regulators), Runtz regulators, and some other electronic devices.
Viper 5704 install questions? Firefighter 1406 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 19 09-04-2016 08:54 AM
Save money!!! 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-12-2015 07:20 AM
1978 parts into my 1965 loquito 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-26-2014 03:41 PM
78 F250 ignition troubleshooting 78madmax 1973 - 1979 F-100 & Larger F-Series Trucks 27 07-01-2014 03:36 PM
Ignition switch - mount spring source... mzerega 1967 - 1972 F-100 & Larger F-Series Trucks 10 02-15-2014 03:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
