Is there any reason I can't...
I have a front sump on my 78 4x4 F250 with a swapped in 460. It has/had 6 leaf wore out HB spring packs on the front. And YES the pumpkin has contacted the oil pan, the PO installed blocks to fix that....I think you will be ok unless you are crazy when you are out wheeling.
Worried, but not enough to get a rear sump, put a little lift on it and drive it. I got some 4" Rough Country springs cheap and put them in place of the wore out HB w/blocks.
I do not think I will have any trouble and I am beating on it either.
That doesn't bother me. A rag is always on hand anyway.
Thats the one. Unfortunately when I gave the core for the motor I have now I gave them everything that came out of the truck. Including the oil pan, oil filter mount, etc.
Adam79
12-21-2014 10:55 AM
410 Highboy
04-29-2009 01:38 PM
dbossman
06-21-2005 02:26 PM
trolly79f150
05-07-2003 10:18 AM
