save Engine cleaning process
I have a 2004 F150 5.4L with 86k on it. It is very dirty and was thinking about taking to manual car wash bay and using the engine clean selection to clean it off.
Is there certain areas I should protect or avoid spraying?
Should I leave the engine running or shut it off to clean?
Any pros/cons on cleaning the engine?
Much appreciated....
I would prefer to not use a pressure washer under the hood with all the electronics there. I would use a good engine cleaner like Kano Labs 'Floway' and rinse with regular garden hose nozzle. You probably will have to do it several times on an engine that has never been cleaned, and you have to get under the truck to do it right.
ace555
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
07-17-2008 09:23 PM
