Not quite your typical "blown" sparkplug - Ford Truck Enthusiasts Forums
Old 02-13-2014, 10:56 AM
busflyer busflyer is offline
busflyer is starting off with a positive reputation.
Wife called yesterday and said the Explorer was making an awful noise. I broke it open this morning thinking I had a collapsed lash adjuster on the left bank. In removing it I pulled the #1 and #2 COP's and could see the #2 COP boot was split about halfway up and had exhaust residue. The plug was still threaded in the head.
The thing is the plug was destroyed. The top portion of the insulator was loose and rattling around in the plug base but what worries me most is the bottom half of the insulator that holds the electrode is gone and, I assume, crushed to dust in the cylinder. They are brand new plugs with less than 2,000 miles on them.
I guess the question is what kind of damage might have been done. Is the loud "Stuck Lifter" noise of days gone by caused by the bad plug or damage done by the insulator in the combustion chamber. For those who have spit plugs in the normal way, did it sound like a loud tapping noise when it let go. The idea of a foreign object in the combustion chamber obviously is very troubling. I'm headed down to the auto parts store now to see if they happen to rent some type of borescope so I might take a look inside. Talked to my Dad and he seemed to think the glass insulator would have been pulverized and blown out and I should just throw another plug in and see what happens. The truck still runs albeit with a miss and the loud noise. 162,000 miles and has given no major problems until now.
Thanks,
Eric
Old 02-13-2014, 12:12 PM
Cheggie's Avatar
Cheggie Cheggie is offline
Cheggie is starting off with a positive reputation.
Hmm, at this point, it's already done what it was going to do. I'd throw in a new plug and try it. If there was a piece of the plug in the cc, it's already ruined the cylinder and piston.
Old 02-13-2014, 12:41 PM
Thanks Cheggie,
No luck on an inspection camera anyway. I gotta get the RA cover back in place and button it up and I guess I'll see what happens. I don't know if the exhaust gases seeping past the plug would ruin the COP or not, guess I'll find out.
Thanks again
Old 02-13-2014, 02:13 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
I would replace the COP regardless.
Old 02-13-2014, 09:51 PM
Well, I finally got it all closed up. Found an additional plug on the left bank with a completely detached insulator. It was intact at least and didn't end up in the CC like the other one. After repairing both of them i fired it up and low and behold I still had a loud tapping. Being frustrated I wound it up to about 3500 RPM hoping to throw something loose and finish it off so I could sell it to the local "you pull it" junk yard but...the noise went away at the top end only coming back at idle and much quieter. Another trip up and down the tachometer and the tapping is gone altogether. I'm glad I found the damaged plugs and I replaced all of them just to be safe but I have no idea what caused my problem. The only thing I can think of is that it was a lash adjuster that had gotten some debris in it and the high revs boosted the oil pressure enough to clear it. Or I could just be full of it, either way I'll take it.
eric
Old 02-14-2014, 09:34 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
That's definitely an odd plug issue---someone here might have an idea just what caused all this.
OTOH even a cheap seldom used borescope is a good investment. There's a few on eBay that attach to a lap top, for less than $100 shipped to your door--worth looking into maybe.
Old 02-14-2014, 11:37 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Were they Bosch Platinum plugs? Those are Junk. Had one fall apart in dad's 89 F150 the platinum electrode wedged between the piston and cylinder and ruined the block.
I will never use them again.
Puking Up Spark Plugs. Spark Plug Blowouts. _Rick_ 1999 to 2016 Super Duty 55 07-19-2015 11:28 AM
My new old truck, 2006 F-150 60000 miles flyguy108 2004 - 2008 F150 0 07-10-2015 11:47 PM
2008 f250 v10running rough and backfiring at idle Dany Boyd Modular V10 (6.8l) 1 06-29-2015 08:18 PM
Head Gaskets 4.0 1991 OHV whale15 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 04-27-2015 04:47 AM
Combustion chamber corrosion grancito General Diesel Discussion 3 04-16-2014 07:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
