1962 F-100 Unibody Disc Brake Conversion - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 02-12-2014, 10:47 PM
62integral 62integral is offline
62integral is starting off with a positive reputation.
Im looking to buy the conversion kit from speedway motors...
Deluxe Disc Brake Kits: 1957-1964 Ford Half Ton - Speedway Motors, America's Oldest Speed Shop
Has anyone had any experience with this kit and how well it installs?
Should I be installing a proportioning valve, double master cylinder and booster? If so would I be able to pull a booster from a 65 f100? What could I pull the proportioning valve and/or master cylinder off of or buy new?
Thanks!!!!
Old 02-15-2014, 05:43 PM
William William is offline
William is gaining momentum as a positive member of FTE.
Save your money. Drum brakes are as good as disk when used on a street driven truck. Ain't no advantage unless you race this thing or haul a lot. One improvement that won't cost a fortune and will provide real safety is a dual chamber master cylinder set up. If you have a few extra bucks add a booster. Power drum/drum brakes have been used successfully for decades and will provide good service for the money. Check out Master Power Brake for some good options. Spend your money on King Pins and bushings, spring shackles and a front end alignment. IMHO.
Old 02-08-2015, 04:37 PM
Koolkat Koolkat is offline
Koolkat is starting off with a positive reputation.
disc swap
I performed the Speedway disc swap on my '62 and it is awesome! Easy to install and you don't need a booster. If you didn't do it yet you should. You cannot source the parts out any less expensive. Use a Master cylinder for a early '70's F150 and a block for a chevy truck, you can get them (the block) from Jegs for about a $50. Have fun! If you have the stock inne wheels, you can either use a 1/2" spacer to clear the calipers or remove the rivets holding the wheels together, remove the center of the wheel and reinstall it backwards, weld the wheel back together and then they will clear the calipers without the use of a spacer.
my Son just purchased a 61 F100 IDIoit 1961 - 1966 F-100 & Larger F-Series Trucks 9 08-15-2016 09:10 AM
1964 Upgrades Madrid1214 1961 - 1966 F-100 & Larger F-Series Trucks 2 06-07-2016 11:26 AM
Speedway Motors Deluxe Disc Brakes Madrid1214 1961 - 1966 F-100 & Larger F-Series Trucks 2 07-21-2015 12:52 PM
Disc Brake kit F100 62 4X4 Blackbird Custom Trucks? DasFord 1961 - 1966 F-100 & Larger F-Series Trucks 19 02-18-2014 10:33 AM
Disc brake conversion possible? 1962 F100 4x4 6 cyl dswhite 1961 - 1966 F-100 & Larger F-Series Trucks 2 10-06-2011 09:46 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
