Petronix for a 62 F100 223 6 Cyl
Pentronix
I have a '62 292/auto. I have a Pentronix in it and I would do it again. I don't know what part number you would need for yours but make sure that they are lined up properly both air gap and height. Mine missed on one cylinder, I couldn't figure it out. I called the hot line and they told me to make sure that the pole piece and the pickup were on the same plane. I shimmed the pole piece with an O-ring and it solved the problem. Good luck. Install the Speedway disc brake conversion also you won't regret it.
ronix08
20
12-27-2015 10:15 AM
richiepan
10-02-2009 05:17 AM
