engine rebuild with minor upgrade suggestions? - Ford Truck Enthusiasts Forums
Old 02-12-2014, 10:42 PM
Rockstar77 Rockstar77 is offline
Rockstar77 is starting off with a positive reputation.
I have a 2000 f150 with180,000 and a 2valve triton 5.4l engine. I want to have it rebuilt it blew the head gasket and I have coolant in the oil. I want to rebuild it with a little more power but mostly i want reliability! I have a guy that sais he can rebuild it with flat top pistons for a little more compression, not much to notice but there. Then we are doing a mild cams and lifters upgrade but not to much we didnt want to mess with the programing, and we wanted to upgrade the bearings for better wear and reliability. He is doing the job with upgrades and 2year unlimited mile for less than $1600. Are there any other suggestions from you out there on upgrades. And are these current upgrades that i plan on doing good? Remember im more for reliability. power is good too but to much can cause other problems so reliability. Ps he said he could do a stock rebuild for $1200
Old 02-17-2014, 08:54 PM
jumpn's Avatar
jumpn jumpn is offline
jumpn is gaining momentum as a positive member of FTE.
I wish I had answers for you. I'm in a very similar situation. 190K miles, pretty sure I have head gasket going out. Always interested a little more power and reliability. It sounds like good prices on your rebuild. I hope to hear some answers with you.
Old 02-24-2014, 01:18 PM
twlightning twlightning is offline
twlightning is starting off with a positive reputation.
I know if it were mine, beefing up the spark plug holes would be on my agenda. Other than that, maybe porting the heads to gasket match and a good valve job. I think having that stuff done and a small bore would make for a great reliable engine. I'd probably be pretty conservative on how much compression unless you want to run premium gas. I'd be interested to know what others say about this specific engine too.
Old 03-01-2014, 08:44 AM
rocknrod rocknrod is offline
rocknrod is starting off with a positive reputation.
No help - But I am about to have the old engine on my 01 5.4 changed out to a new Ford Dealer bought 5.4
After almost 300,000 miles I figure it's time to avoid the bullet.
Upgrade turbo, can my studs take it?? Leatherneck007 1994.5 - 1997 7.3L Power Stroke Diesel 18 05-13-2016 09:15 PM
1995 F250 351W to 460 or V10 dauntlessmotors Engine Swaps 3 12-09-2015 04:49 PM
The Skurg - need feedback on preventative maintenace and some mods mb_01sc Excursion - King of SUVs 7 07-23-2015 09:59 PM
Fuel system maintenance/upgrades the_auto_tech 6.0L Power Stroke Diesel 5 01-20-2015 02:26 PM
Thinking about swapping my C4 for AOD...Any Suggestions? cooktimj 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-21-2013 05:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
