hydroboost leak question - Ford Truck Enthusiasts Forums
Old 02-12-2014, 08:18 PM
okie72 okie72 is offline
okie72 is starting off with a positive reputation.
I recently did the hydroboost conversion on my truck it works great but I have a leak between the hydroboost unit and the master cylinder. It drips out there when my foot is on the brake. It is power steering fluid that is leaking. Is there a seal in the hydroboost that can be replaced or do I just need to buy a new hydroboost unit? It is a used hydroboost from a 1999 f450.
Old 02-15-2014, 08:22 AM
Any hydroboost guys out there?
Old 02-15-2014, 08:54 AM
gatorfor88's Avatar
gatorfor88 gatorfor88 is offline
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
I would imagine you can do some research on the web and find your answer.
Old 02-15-2014, 09:31 AM
Yes I am currently reading here on the forum. I thought I read something about you needed to use a F250 master cylinder but I can't find the thread.
Old 02-15-2014, 09:35 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
I used the MC from the same year truck. Mid 90's F450.
Sorry, I have not had it apart yet...thankfully.
Lincoln Hydroboost upgrade?? 77_crew 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-15-2016 04:30 PM
Hydroboost gurus mike1202002 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-01-2016 11:56 PM
Hydroboost ATF Leak jmaskew 6.0L Power Stroke Diesel 3 11-30-2015 02:20 PM
Hydroboost Leaking iron1951 6.0L Power Stroke Diesel 7 07-25-2014 09:24 AM
Power Steering Leak Near Hydroboost kwissman 6.0L Power Stroke Diesel 4 03-20-2011 09:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
