bracing under hood
bracing under hood
My 51 came bare bones plus a pile of parts. Now that I am working on the hood I was wondering a couple of things.
1 Is there a peice of sheet metal that fits under the hood? (I have a peice that looks like it should fit but it hits the rad when you close the hood)
2 If so can some one send me some picts on where it should go and what it looks like when it is instaled.
3 Is the rad susposed to be shimmed back to make the shroud thing work?
Just a couple of questions
thanks Angus
thanks Angus
bracing under hood
1. yes
2. my daughter borrowed my digital camera - soon as I get it I can get you a pict.
You're talking about the sorta 'U' shaped panel that comes down from the hood around the top of the radiator - I think. It is an air-dam to divert air thru the radiator.
The hood has two sets of mounting holes for both 6 cylinder (forward set) and V8's (rearmost set) although in Canada with only V8's I don't know if this is true.
3. You shouldn't have to shim the radiator back
bracing under hood
Check out the links below
http://www.vanpeltsales.com/FH_web/F...51_F1truck.jpg
