swap 4speed to 5 speed
hey there,
my 1984 f150 has a 4 speed with granny low, and it does enough highway driving that I'm wondering if it would be worth swapping to a 5 speed whenever this transmission kicks the bucket, or sooner if I can find a garage that wants to make a trade? is it a hard procedure, or just a bolt and go?
thanks
-Andrew
thanks
-Andrew
hey there,
thanks
-Andrew
thanks
-Andrew
The ZF trans has a low (5.72 iirc) first gear. The Mazda uses a 3.91 (iirc) first and has closer ratios. The ZF is stronger than the Mazda box.
Both use internal concentric hydraulic throwout bearings. Adapting your set up to that may take some doing. You must also be sure the bearing matches the trans and clutch components.
You will probably be in for crossmember and driveshaft work as well.
And you may need to modify your transmission cover in the cab, as they may be taller than your current trans.
Worth it? Depends on how lucky you get in finding a serviceable trans at a reasonable price, and if you can do the labor yourself.
If you have to hire this done, it will never pay back in gas mileage.
Andrew - You really need to help us help you by placing info about your truck in your sig. Or, in posts where you ask a question. Otherwise we have to relie on memory and "assume" we know, and that's not good.
There are three different transmission bolt patterns and three different transmissions:
- Small Block:
- 300 six/302/351W
- Integral slave cylinder, meaning it is inside the bell housing and fits behind the throw out breaking on the input shaft
- Big Block:
- 429/460 with no mods
- 351M/400 with mods
- External slave cylinder with release lever
- Diesel:
- 6.9 & 7.3L
What ever you do don't use the Mazda top loader 5 speed. I have one in my 95 F150 4x4 302. It works OK but they are not very strong. I baby mine just because I know their reputation. The Mazda 5 speeds are pretty common. If I had a ZF I would swap mine out & never think twice.
If you lost a clutch with the Mazda 5 speed trying to shift them without a clutch is near impossible. 1st to 2nd it can be done but the rest I have never been able to shift without a clutch. My Ranger's were the same.
