Any pics of ccv bypass into the exhaust
Old 04-19-2016, 07:14 AM
Jenksie13's Avatar
Jenksie13
Jenksie13 is offline
I have a no limit CCV bypass and have noticed that there is a considerable amount of blow by coming out the pipe and it's noticeable when I'm at a stoplight or drive-thru and I'm wanting to run it into the exhaust but not sure the right way to do it I don't want to create pressure from the exhaust pipe. Does anyone have pictures of how they've done it and a quick explanation.
Old 04-19-2016, 11:06 AM
UGA33's Avatar
UGA33
UGA33 is offline
Something like this is what you would want to do. If I (let's be honest) when I do my kit, it will look something like this. Keep it at a 45* angle and you should be good.
Old 04-19-2016, 04:13 PM
Jenksie13's Avatar
Jenksie13
Does it need to extend into the pipe some and you don't think it will create any pressure even at wide open throttle? Ever since I installed an 63mm non vgt kit it seems to have been smoking more.
Old 04-19-2016, 09:36 PM
UGA33's Avatar
UGA33
UGA33 is offline
It will need to extend into the exhaust. At the right angle, it will pull a slight vacuum with no issues.
GreenMachinee
11-19-2014 06:17 PM
51fordf5
05-06-2012 11:04 PM
Adam0331
08-24-2008 10:35 PM
cgrandahl64
12-08-2005 04:54 PM
loudwayne
01-10-2004 07:32 PM
Quick Reply: Any pics of ccv bypass into the exhaust
