P0300 which plug is it - Ford Truck Enthusiasts Forums
Old 02-11-2014, 07:45 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
Which plug is misfiring. It says random misfire. Which plugs going to hell on me?? Truck has 130k on it
Old 02-12-2014, 10:14 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
P300 would indeed be a random misfire----codes like P304 P305 etc would indicate a known cylinder misfire.
You may have a faulty wiring connection or perhaps the crank position sensor is causing this?
Might have to do some digging into the wiring to see if the problem exists there.
Old 02-13-2014, 02:07 PM
Aune163rd's Avatar
Hmm, what Is a CMP sensor? I was told that was a possible cause....but I have no idea what that is.
Old 02-14-2014, 09:47 AM
JWA's Avatar
JWA JWA is offline
Not sure what the CMP sensor would be----I'm still of the thought this is a wiring problem relating to the crank position sensor though.
Old 02-15-2014, 12:36 PM
Aune163rd's Avatar
CMP: Crankshaft Monitoring something.....
Old 02-16-2014, 06:29 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
It helps a lot if you actually identify specifically what you're working on.
A P300 means the PCM can't determine the misfiring cylinder accurately or there are multiple misfiring cylinders. Your best bet is to go in and look at the misfire count PIDs in mode 6, test 53 and see if you can get more data. Other faults such as a weak cam sensor or EGR system problems can also cause problems.
Old 02-22-2014, 10:53 AM
Aune163rd's Avatar
I have no idea what PID means nor do I know what test 53 is. Can you guys further explain it??
Old 02-23-2014, 02:32 PM
Aune163rd's Avatar
Got it to throw another code. Cylinder 4 misfire. Now what do I do. There are no other codes besides the two. What do I do now??
Old 02-23-2014, 06:02 PM
Start with fixing the #4 misfire.
Old 02-25-2014, 11:41 PM
Aune163rd's Avatar
How do I go bout fixing it? SHould I just replace the COP and the plug??
Old 02-26-2014, 07:49 AM
That works about 90% of the time.
Old 02-26-2014, 10:59 PM
Aune163rd's Avatar
what about the other 10%. What else could it be?
Old 02-27-2014, 09:47 AM
BOSSHOGG250SDV10 BOSSHOGG250SDV10 is offline
BOSSHOGG250SDV10 is starting off with a positive reputation.
Same problem P0300
Same issue with a 99 F250SD V10. Getting P0300 and P0308. Changed the COP and plug on #8 and still getting the P0308. Found the double split PCV elbow hose in front of the TB and replaced it. Cleaned MAF and ran a tank of gas with Sea Foam. EGR was just replaced by dealer a couple of months ago. LTFT is good but STFT has a delta of 20% plus. Any other ideas?
Old 02-27-2014, 10:19 AM
Quote:
Whole bunch of things.
PCM, wiring harness and connectors, injector, base engine mechanical concerns (intake leak, valves, rings, other faults, etc), to name most of them.
Old 02-27-2014, 10:44 AM
Yep the last 10% is really hard unless you get lucky and not to mention time consuming. I may swap the #8 fuel injector to see if the misfire moves. After that it will be off to the Ford dealer!
misfire nightmare cottonf150 1997 - 2003 F150 9 02-02-2015 10:53 PM
Misfiring nmcorbett99 1999 to 2016 Super Duty 0 12-21-2014 08:33 PM
Occasional Misfire Which Cylinder? dunebuggys 2004 - 2008 F150 6 06-22-2014 09:16 AM
1999 Ranger 6cyl 4.0L 4X4 Misfire dwollum Ranger & B-Series 2 04-13-2014 01:46 PM
Gotta misfire on #2. Did lots of tests, can't find cause of misfire, now... Methodical_1 1997-2006 Expedition & Navigator 8 02-15-2013 01:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
