2005 f-350 electrical problem? Need help - Ford Truck Enthusiasts Forums
Old 02-11-2014, 11:27 AM
Grizz350 Grizz350 is offline
Grizz350 is starting off with a positive reputation.
Started my truck today and it started for couple seconds then I went to turn my headlights on and it died. Now it won't turn over at all not even by gettin jumped got the battery load tested and it was fine. Also every now in the my aftermarket radio would turn on it off to I don't kno if this would cause this's also none of my lights come on inside or outside I put the key in and nothin happens except for a clicking sound like a relay clicking and my speedo is stuck over a hundred and no lights or gauges move when I turn the keys on and also I have to disconnect the battery cause the clicking sound continues even with the keys out ? Any ideas anyone what this could be ?
Old 02-14-2014, 11:39 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum. Sounds like you have a bad ground somewhere. Check both ends of the main ground cable and all of the body grounds as well.
F350 won't start - alternator or battery? billenglish61 1999 to 2016 Super Duty 3 11-22-2015 02:45 PM
Bad ground? Dead switch? Help! Dead Truck 1999 to 2016 Super Duty 5 05-08-2014 09:05 AM
Sterter Question--96 F-250 NicktheBrit 1987 - 1996 F150 & Larger F-Series Trucks 2 04-11-2014 02:44 PM
EMERGENCY. stuck on side of road won't turn over dougjohnson72 Ford Inline Six, 200, 250, 4.9L / 300 8 12-10-2013 11:26 PM
I turn the key it just clicks taandctran Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 06-02-2010 11:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
