Manual transmission problems
Old 02-11-2014, 01:52 AM
Inline6xl's Avatar
Inline6xl
Inline6xl is offline
Cool Manual transmission problems
I have a. 1996 ford f150 xl 4.9 5 speed manual transmission. And now when giving it gas it 4th or 5th. It feels like it's slipping. The revs going higher but I don't speed up. Some times I got a slight burning smell. It shifts fine in all gears. I have to let the clutch almost all the way out to engage a gear. HopinG it's not the transmission
Old 02-11-2014, 02:18 AM
88n94's Avatar
88n94
88n94 is offline
Your hope came true it's not the transmission, it's the clutch. Do you have a 2 wheel drive or 4 wheel drive?
Old 02-11-2014, 07:41 AM
Inline6xl's Avatar
Inline6xl
4 wheel drive. So how does that work
Old 02-11-2014, 10:27 AM
88n94's Avatar
88n94
88n94 is offline
It's just that a 4 wheel drive is a lot more work to remove and re install the transmission.
Old 02-11-2014, 11:50 PM
Inline6xl's Avatar
Inline6xl
Well I've done my research. Buying a clutch set up with the internal slave cylinder and might go ahead and replace a few seals while I'm at it. I've received one quote of 1100 from ammco. More then likely just going to do it my self with a few friends. Still in the fence though. Any recommendations as far as clutch goes. So far zoom and even center force sound pretty good for the money.
Old 02-12-2014, 01:32 AM
88n94's Avatar
88n94
88n94 is offline
I would just go with the stock style clutch setup myself. You may be able to get a very good deal on the whole package from Ford, believe it or not. The whole package being the clutch disc, pressure plate, pilot bearing, slave cylinder and throwout bearing and I believe they even include a plastic alignment tool in the package.
Whatever you do don't use a parts store slave cylinder. We read of too many of them failing in a very short time. Get a genuine Ford slave cylinder.
Old 02-14-2014, 11:56 AM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
Yep!!! Definitely the clutch.
Old 02-15-2014, 12:56 AM
Inline6xl's Avatar
Inline6xl
Anyone think this is a good replacement clutch?
1995-97 Over 8500GVW 4.9L 11" LUK clutch kit
Old 02-16-2014, 06:13 AM
FuglyF100's Avatar
FuglyF100
FuglyF100 is offline
STAY AWAY FROM AAMCO! They are about as good as letting Wal-Mart work on your vehicle...
That clutch looks pretty nice. LUK is a good brand.
Old 02-16-2014, 06:44 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
That clutch is "for over 8500GVW 11".
You have an F150, I don't see it having a Gross Vehicle Weight rating over #8,500.
Are you sure your flywheel is drilled for the larger clutch plate?
It would suck to have it all apart and find out that it doesn't fit.
Old 02-16-2014, 06:52 AM
FuglyF100's Avatar
FuglyF100
Oops, I didn't see the GVW specs. Looks like this would be the correct clutch for that application:
Amazon.com: LuK 07-128 Clutch Set: Automotive Amazon.com: LuK 07-128 Clutch Set: Automotive
Old 02-16-2014, 07:21 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm not saying it won't fit, just that it would be good to know before it's gutted in the driveway.
I replaced my T-19 with a ZF5-s42 only to discover that the pressure plate would not bolt to my flywheel.
I don't know anything about the flywheel on a 1996 4.9.
Old 02-16-2014, 07:23 AM
Inline6xl's Avatar
Inline6xl
Isn't that still the 11 inch clutch?
Old 02-16-2014, 07:57 AM
FuglyF100's Avatar
FuglyF100
Different transmissions. An F-250 and larger is going to have a ZF5 trans and your F-150 has the M5OD-R2.
Old 02-16-2014, 08:37 AM
Inline6xl's Avatar
Inline6xl
So I can upgrade to an 11 inch clutch but as long as it's not the 8500gvwr. This one should work then. Anyone done the 11 inch upgrade.
1995-97 4.9L 11" LUK Pro Gold clutch kit
Quick Reply: Manual transmission problems
