7.3 Dead Dead
7.3 Dead Dead
Hi folks, I hate to start out this way, but I need some advice. I just went out to start my 1997 F250 7.3, but no luck. The truck has 150k and the batteries are six months old. I drove the truck just fine yesterday for two hours, no problems. When I energized the ignition all the normal lights came on and I waited for the glow plug lights to go out, the starter kicked over for a second then everything went dead- no interior lights, no dash lights, nada.
I don't yet have a service manual for this truck and I don't know my way around it yet. Has anyone had this issue? I'm thinking a blown relay or main fuse, any ideas? Thanks!
Im with the two guys above had this happen to me about a month ago, bad battery connections, i was searching all over for a blown fuse or broken wire only to causally glance at my corroded battery connections several hours later and go SOAB thats it right there! cleaned them up and good as new!
I started by charging each battery individually, the first was fine but the second seemed iffy as the charger instantly dove below the scale and I realized something was up. I took both back to the store I purchased them and they confirmed that the second battery was indeed faulty after only six months. ( Bosch batteries). Thank God that's all it was! I cleaned the terminals, ( I also took the opportunity to wire brush and apply rust converter to my battery trays) lubed the connections and the truck fired right up. Thanks again for the suggestions!
nicksorenson
07-18-2017 07:07 PM
96_Powerstroke
11-06-2014 09:28 AM
bttf
02-24-2013 10:54 AM
Mav186
1999 to 2016 Super Duty
09-14-2010 08:00 AM
ztmike
10-26-2009 09:12 PM
