Outside Rear Veiw Mirrors - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-13-2014, 07:21 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
Quote:
Originally Posted by 49willard View Post
Ben, What are you currently using for mirrors that don't work? Are they the same mirrors that Chuck is using? I ask since I have a pair of the same ones as Chuck is using AND I plan to use them to pull an enclosed trailer (trailer sides inside the trailer wheels). When I got Willard, he had had the typical west coast mirror which I will not go back to.
I do like the way these look on the truck but I am not sure how well they are going to work. They may be a little small if the truck was used regularly for towing a trailer. I was thinking of maybe changing the mirror to a 5" simmiliar to what is used on a early Chevy but I going to give these a try first.
  #32
Old 02-13-2014, 11:16 PM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
I also have a peep mirror on the drivers side and want to get another one to for the passenger side. I like having both mirrors... Just need to get chrome mirror heads for the lower mirrors...
  #33
Old 02-14-2014, 05:39 AM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
I had the same mirror on my 38 Woodie back when and it was OK, however, I was not towing with it.
<center></center><center> </center><center>These were the mirrors that were on Willard when I bought him back in the late 70's. Great for trailering but they are long gone and will stay gone!</center>
  #34
Old 02-14-2014, 07:30 AM
ChuckRob's Avatar
Bill, I agree, Those were really butt ugly.
  #35
Old 02-14-2014, 01:54 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Quote:
Originally Posted by ChuckRob View Post
I just purchased some and was installing today. I ground the hinge down to fit the mirror arm, tapered the new pin, thought that everything was lined up right, The pin went down ok but when I gave it a tap to set the splines on the pin the bottom of the arm broke. The arm looks like it is just chrome plated pot metal. I know that most of this repo stuff is just imported crap but I would like to get some quality mirrors and I don't mind spending a little extra for good stuff. I did not buy my mirrors from the vender that I got the picture from by the way.
I had the same problem. I like the shape of the mirrors but the hinge mount is not a good design. I got mine from Speedway. I asked them how to get a new bracket and they sent me a new mirror at no charge.
I also found these larger stalk mirrors that I thought that I could use if I want to tow a trailer.
  #36
Old 02-14-2014, 04:58 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
^^^^^^^ Where did you get the rectangle one's? they look like they're stylish and practical.
  #37
Old 02-14-2014, 07:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
They appear to be motorcycle mirrors?
  #38
Old 02-15-2014, 07:29 AM
petemcl's Avatar
Still Learnin'
Quote:
I think that I saved that picture from eBay. They delete things after a while so I can't find the link. I'll keep looking.
Motorcycle . . . Maybe Ross but I found them under a truck search.
EDIT: I found these square mirrors which should work. I think that they should fit on the curved hinge pin arms.
https://www.streetrodhq.com/detail/15882/Rectangle_Billet_Mirror_Head_Large.html
  #39
Old 02-16-2014, 06:41 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Here is the mirror C&G is selling:
The arm can be extended, the angle of the arm adjusted, and the mirror itself can be unbolted. I think the mirror is larger in diameter than the more decorative mirrors discussed above in this thread.
Here is a close up of the hinge mount area. This mirror also comes with a hinge pin.
  #40
Old 02-16-2014, 10:45 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
I'm glad I saved a link to the information on how to block posts.
I had undone that a while back to give a member the benefit of the doubt, but now I'm convinced I don't want to ever read anything he ever says again.
mirrors jle70 1994.5 - 1997 7.3L Power Stroke Diesel 7 11-06-2015 09:01 PM
Mirror parts luvatruck 1999 - 2003 7.3L Power Stroke Diesel 3 02-01-2015 11:46 AM
Mounting Tow Mirrors Corkwheats 1967 - 1972 F-100 & Larger F-Series Trucks 23 11-11-2014 08:36 PM
Parts wanted, Stock rear view mirror, anyone jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 08-31-2014 10:18 PM
Aftermarket mirror vibration BigBlkEX Excursion - King of SUVs 18 08-19-2014 12:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
