Engine sputter when accelerating - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 02-10-2014, 08:41 PM
criggs1 criggs1 is offline
criggs1 is starting off with a positive reputation.
My daughter has a 2002 Escape 4WD with 3.0L engine.
Coming home from school a few weeks ago she experienced engine running rough on the highway when trying to accelerate. We ran the diagnostic on it and it revealed that #2 cyl coil was misfiring.
I've replaced all of the rear bank coils (in hopes that I wouldn't have to remove the intake manifold again anytime soon). I also replaced the connectors and weatherproofed them.
Replaced all the plugs while I had easy access too. This all went pretty smooth with exception of breaking 3 of the 5mm coil bolts off inside the valve cover.
I've also replaced the upper and lower intake manifold gaskets.
It runs much better now except now on the highway, at 1800 rpm/55 mph if I try a gradual acceleration I get engine sputtering and it won't accelerate. If I push hard on the pedal it will downshift and accelerate normally right past this trouble spot. Other than this it idles and runs great.
I've noticed that the 3/4 in. vac hose on back of manifold is getting pinched closed about 70%. this is the hose that leads down to the top of engine just below lower manifold. I suspect this is the problem but cannot determine the root cause. I assumed it was the intake manifold gaskets but those are now replaced.
Any help would be greatly appreciated.
Craig
Old 02-14-2014, 04:55 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
The 3/4 house is the pvc valve line its . I would try to read for codes you could have a pending code. Also I'd try some good gas treatment and clean the maf sensor.
I assume its an Electrical Gremlin?? MT441 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 10-23-2015 10:48 PM
2002 Escape Random Misfire, High Idle, and CAT prob fixed... WB4IUY Escape & Escape Hybrid 0 07-13-2014 03:01 PM
2000 expedition 5.4 engine miss Joefish1943 1997-2006 Expedition & Navigator 4 04-01-2012 05:31 PM
4.9L 300 Motorhome missing on acceleration and idle too high CoachmenCaperXl Ford Inline Six, 200, 250, 4.9L / 300 43 10-30-2011 03:36 PM
P0305 & P0306 HELP! AlexsDad 2004 - 2008 F150 4 06-17-2011 12:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
