Re-setting tire pressure
I drove off the car lot with 6.2L Super Duty Platinum that I wanted. But as I have learned more about it, I realized that my tire light is on. So I took all 4 tires up to 60 lbs. My tire gage only registers to 60. Bought a new gage today that goes up to 70 lbs. My inside door printout said that Michelin prefer 65 lbs. My Camry re-sets itself when you bring all 4 wheels into range, not the Platinum. Help !!!! Has anyone re-set their tire pressure yet? There is just so much to read and learn about this truck. I can use any and all help that I can get.
Congrats on the truck. The owners manual has detailed info on the TPMS. My sensors generally trip at 60 PSI. I generally keep 72PSI all around. Once the tires are correctly filled, you will generally have to drive around the block to get them to reset. IIRC, 20 MPH for 2 minutes. Most of the time, the pressure light indicator will go out after just going down the street (150 feet or so) If your light still trips, I believe the dealership should be able to have the range lowered for tripping the indicator light.
Good Luck!
Good Luck!
Thank you very much. I think that I probably got 58.5 to 59 lbs. in one or two tires. I was a little scared to depend on a gage that was on its very upper limit. I feel more re-assured and I will check the door again and run the pressure to where it should be. Thanks everyone for your help.
I got a dealer to reset my tpms set point to 55 psi, they did it free with an oil change, but it was not the dealer I purchased the truck from, they would not do it, or didn't know how? I run 65 when towing and 55 when not, factory was 75 or 80, I don't run my truck to max loads and check my tire temps at every rest stop.
I got a 14 SD with the 20 in rims.tires..Michelin LTX's my door sticker says Cold Tire Pressure 65 psi..for front and rear..so that is where I set them in the morning..
Reset proceedure from the manual...
To provide the vehicle’s load carrying capability, some vehicles require
different recommended tire pressures in the front tires as compared to
the rear tires. The tire pressure monitoring system (TPMS) equipped on
these vehicles is designed to illuminate the low tire pressure warning
light at two different pressures; one for the front tires and one for the
rear tires.
Since tires need to be rotated to provide consistent performance and
maximum tire life, the tire pressure monitoring system needs to know
when the tires are rotated to determine which set of tires are on the
front and which are on the rear. With this information, the system can
detect and properly warn of low tire pressures.
TPMS reset tips:
• To reduce the chances of interference from another vehicle, the TPMS
reset procedure should be performed at least three feet (one meter)
away from another Ford Motor Company vehicle undergoing the TPMS
reset procedure at the same time.
• Do not wait more than two minutes between resetting each tire sensor
or the system will time-out and the entire procedure will have to be
repeated on all four wheels.
• A double horn chirp indicates the need to repeat the procedure.
Performing the TPMS reset procedure
It is recommended that you read the entire procedure before attempting.
1. Drive the vehicle above 20 mph (32 km/h) for at least two minutes
and then park in a safe location where you can easily get to all four tires
and have access to an air pump.
2. Place the ignition in the off position and keep the key in the ignition.
3. Cycle the ignition to the on
position with the engine off.
4. Turn the hazard flashers on then
off three times. This must be
accomplished within 10 seconds.
If the reset mode has been entered successfully, the horn will sound
once, the TPMS indicator will flash and the message center (if
equipped) will display TRAIN LEFT FRONT TIRE. If this does not
occur, please try again starting at Step 2.
If after repeated attempts to enter the reset mode, the horn does not
sound, the TPMS indicator does not flash and the message center (if
equipped) does not display TRAIN LEFT FRONT TIRE, seek service
from your authorized dealer.
5. Train the TPMS sensors in the tires using the following TPMS reset
sequence starting with the left front tire in the following clockwise
order:
• Left front (Driver’s side front tire)
• Right front (Passenger’s side front tire)
• Right rear (Passenger’s side rear tire)
• Left rear (Driver’s side rear tire)
6. Remove the valve cap from the valve stem on the left front tire;
decrease the air pressure until the horn sounds.
Note: The single horn chirp confirms that the sensor identification code
has been learned by the module for this position. If a double horn is
heard, the reset procedure was unsuccessful, and must be repeated.
7. Remove the valve cap from the valve stem on the right front tire;
8. Remove the valve cap from the valve stem on the right rear tire;
9. Remove the valve cap from the valve stem on the left rear tire;
Training is complete after the horn sounds for the last tire trained
(driver’s side rear tire), the TPMS indicator stops flashing, and the
message center (if equipped) displays:
TRAINING COMPLETE.
10. Turn the ignition off. If two short horn beeps are heard, the reset
procedure was unsuccessful and must be repeated.
If after repeating the procedure and two short beeps are heard when the
ignition is turned to off, seek assistance from your authorized dealer.
11. Set all four tires to the recommended air pressure as indicated on
the Safety Compliance Certification Label or Tire Label located on the
B-Pillar or the edge of the driver’s door. See Vehicle loading - with and
without a trailer in this chapter for more information.
rear tires.
TPMS reset tips:
order:
TRAINING COMPLETE.
Info appreciation
Thank you for all of the helpful information. I know that without it, I will be buying a lot more tires and voiding a lot more warranties. But, it is just a shade above walking. This is really a lot of knowledge to retain, hopefully they will find a way to simplify it in the future.
Has anyone tried this procedure? I'm confused a bit. Do you want to have them at the pressure you want the sensors to be reset at from the start or something..? I don't see how else you can reset them unless the display has a reading you can adjust... Or is this whole ridiculous procedure just to reset a warning light that won't go off? Again, has anyone here actually done this?
re-setting pressure
Tire pressure light came on. My gage only went to 60 lbs. I set the tires to 58.5 to 59.5 and the light did not go out. After consulting on FTE, I bought a 70 lb gage and inflated tires to 65 lbs. Light went out. Truck handles well. I found out that I needed to inflate the tires to at least 60 lbs. as the info on the pole required that they be inflated to 65 lbs.
Good Luck.
