Transmission will not up shift in low range
My 1996 F250 with E04 trans will not upshift when transfer case is in low range. Once in a while it works fine, most of the time the trans will stay in low gear. In high range or 2WD, the transmission shifts fine. I don't understand the relationship, the transmission does not know what range the transfer case is in, does it?
Does the low range light on the dash light up?
If not the low range switch is probably the problem, if the light does light check the circuit low range switch to pin 12 PCM (Lt blu-blk wire).
Changes shift schedule for low range, computer doesn't know low range has been selected it doesn't shift soon enough.
As Dan asked, does the 4x4 Low Range light on the dash light up?
jfarmer
09-13-2014 07:45 PM
Christof13T
1999 to 2016 Super Duty
06-07-2012 12:20 PM
