1975 F250 Bumper Towing Options - Ford Truck Enthusiasts Forums
Old 02-10-2014, 10:49 AM
1975FordF250 1975FordF250 is offline
1975FordF250 is starting off with a positive reputation.
I have a 1975 F250 Camper Special Custom, everything seems to be more heavy duty than the normal trucks. The side says 8000 GVW and suspension is beefy.
I bought a 2" trailer hitch receiver that is close to fitting this truck (got it for very cheap) and I was going to modify it to fit. I noticed the rear bumper isn't like most bumpers I've seen. It's bolted to the frame in numerous spots and looks very thick.
I can't find a stamped exact towing capacity on the bumper, but it seems like most are rated 4000-5000lbs towing and about 500lbs tongue weight. Did these models come with a slightly better rear bumper or would it be the same as other F250 bumpers?
The hitch receiver it rated at about the same as the bumper. So I figured maybe just weld a 2" square tube to the bottom of the bumper so I could use different hitches/***** to get the right height. Does that seem like a decent idea or should I just stick with the receiver and make it work?
Old 02-10-2014, 11:10 AM
jgavac's Avatar
jgavac jgavac is offline
jgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to all
If you could post up some pics, that'd help.
Stock bumpers bolt on in 4 locations. 2 on either side of the frame.
Aftermarket bumpers are common, but most people weld them on.
I'm not a big fan of bumper towing. For one, you're at a fixed height. Two, they are not rated for much (I can't imagine 5000 lbs...). Three, the trailer is so close to the truck that, depending on the trailer design, could be damaging if you jackknife the trailer while backing up, or are needing to make a sharp corner (intentional jackknife) If you've got a receiver that will fit or can be made to fit, I'd use that. Gives you more options for the differences in trailer heights, among other things.
Just my $0.02
Jameson
Old 02-10-2014, 03:21 PM
Here are some pictures below. What I meant was instead of just the ball on the bumper, weld/bolt the 2" square tube underneath (1/2 pictures) and then I could use different hitches and ***** to get the height I want. Just like with the receiver only it's attached to the bumper.
The camper special has these side brackets also, which have 3 bolts to the frame for the bumper and it bolted to there and another bracket to the side (pictures 3 and 4). What I was thinking was to have a brace (some heavy gauge steel pipe) from these side brackets to the bumper for more support (picture 5) and also bolting to the factory brace to create an X brace.
I could also add a brace in the middle from the frame to the middle of the bumper where the 2" square tube would be (picture 6). This would actually be stronger than just a receiver I think.
Old 02-10-2014, 05:53 PM
Leef250 Leef250 is offline
Leef250 is starting off with a positive reputation.
I also have a similar bumper that has a built in receiver under the bumper and did find one online that was rated at 5k towing. was also thinking if I should change it to a standard bumper and get a aftermarket receiver under it or just stick with the bumper and built in receiver that I have now.
Old 02-10-2014, 06:48 PM
Quote:
It seems to me that the bumper (at least mine) is the exact same as an aftermarket receiver, it's bolted to the frame (3 bolts each side for me). Also the bumper seems like it would distribute the load better. I really wasn't expecting the bumper to be so beefy and so well reinforced.
Old 02-10-2014, 06:56 PM
spikinfool05's Avatar
spikinfool05 spikinfool05 is offline
spikinfool05 is starting off with a positive reputation.
i have towed many loads with just the bumper. thing is like jgavac was saying some trailers do get close to the truck. grandpa used to pull 2 loaded hay racks 6 bales high all the time with his 74 2x4. tires spinning all the way up the big hill next to his house.
Better receiver hitch? MarkyB98 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 20 10-28-2016 06:15 AM
Adding receiver to a 2013 galaxie641 2009 - 2014 F150 3 10-08-2014 09:34 AM
Frame Differences F150 - F250 BCHauler 1987 - 1996 F150 & Larger F-Series Trucks 4 05-16-2010 10:48 AM
Tow hooks on rear bumper 95bogginbronco 1978 - 1996 Big Bronco 5 07-12-2007 11:44 PM
Hanson Enterprise bumpers swilson 1999 to 2016 Super Duty 0 08-19-2005 10:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
