6.2L V8 Discuss the 6.2L V8
rough idle when temp under -30
Old 02-10-2014, 08:22 AM
dwh039's Avatar
dwh039
dwh039 is offline
Everytime I start my 2011 f250 6.2, with ambient temperature at -30 or colder. I get an extremely rough idle for roughly 10 to 30 seconds in length. Sounds like it is running on only 4 cylinders, then you I will hear a popping noise and it idles normally after that. My guess is an exhaust restriction of some sort, maybe egr valve related. It never throws a code during or after the rough idle. Also doesn't matter if its plugged in or not. Any ideas? Also truck has roughly 100k miles on it.
Old 02-10-2014, 08:59 AM
T diesel's Avatar
T diesel
T diesel is offline
I'd change the oil to full synthetic 0 /20
@-30F.
Old 02-10-2014, 09:37 AM
eberlestock's Avatar
eberlestock
eberlestock is offline
Mine did this for the first time yesterday. It only idled rough for about 5 seconds but this is the first time. I run royal purple 5/20. I usually plug my truck in but didn't have it plugged in yesterday. It was -24C.
Old 02-10-2014, 10:48 AM
dwh039's Avatar
dwh039
dwh039 is offline
I run full synthetic 5w20 with an oil pan heater, so I don't think oil flow is my issue.
Old 02-11-2014, 09:10 PM
brickman's Avatar
brickman
brickman is offline
Could it be the gas blend ?
Old 02-11-2014, 09:43 PM
dwh039's Avatar
dwh039
dwh039 is offline
5% ethanol blend from above ground tanks and a high volume cardlock.
Old 02-12-2014, 07:05 AM
JohnnyThunder's Avatar
JohnnyThunder
JohnnyThunder is offline
Interesting, mine does not do anything like that even at -35.
Old 02-12-2014, 08:23 PM
KSCRUDE's Avatar
KSCRUDE
KSCRUDE is offline
Originally Posted by dwh039
Everytime I start my 2011 f250 6.2, with ambient temperature at -30 or colder. I get an extremely rough idle for roughly 10 to 30 seconds in length. Sounds like it is running on only 4 cylinders, then you I will hear a popping noise and it idles normally after that. My guess is an exhaust restriction of some sort, maybe egr valve related. It never throws a code during or after the rough idle. Also doesn't matter if its plugged in or not. Any ideas? Also truck has 100k miles on it.
Omg, will it start at -30 when not plugged in. If Its that cold, I don't even want to get out of bed. Global warming my ars.
madpogue
08-21-2009 03:15 PM
BassCatSC
02-26-2004 08:33 AM
jobguy
11-20-2003 11:29 AM
enulsen
03-13-2001 06:02 PM
Quick Reply: rough idle when temp under -30
