rough idle when temp under -30 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 02-10-2014, 08:22 AM
dwh039 dwh039 is offline
dwh039 is starting off with a positive reputation.
Everytime I start my 2011 f250 6.2, with ambient temperature at -30 or colder. I get an extremely rough idle for roughly 10 to 30 seconds in length. Sounds like it is running on only 4 cylinders, then you I will hear a popping noise and it idles normally after that. My guess is an exhaust restriction of some sort, maybe egr valve related. It never throws a code during or after the rough idle. Also doesn't matter if its plugged in or not. Any ideas? Also truck has roughly 100k miles on it.
Old 02-10-2014, 08:59 AM
T diesel T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
I'd change the oil to full synthetic 0 /20
@-30F.
Old 02-10-2014, 09:37 AM
eberlestock's Avatar
eberlestock eberlestock is online now
eberlestock is gaining momentum as a positive member of FTE.eberlestock is gaining momentum as a positive member of FTE.
Mine did this for the first time yesterday. It only idled rough for about 5 seconds but this is the first time. I run royal purple 5/20. I usually plug my truck in but didn't have it plugged in yesterday. It was -24C.
Old 02-10-2014, 10:48 AM
I run full synthetic 5w20 with an oil pan heater, so I don't think oil flow is my issue.
Old 02-11-2014, 09:10 PM
brickman brickman is offline
brickman is gaining momentum as a positive member of FTE.
Could it be the gas blend ?
Old 02-11-2014, 09:43 PM
5% ethanol blend from above ground tanks and a high volume cardlock.
Old 02-12-2014, 07:05 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
Interesting, mine does not do anything like that even at -35.
Old 02-12-2014, 08:23 PM
KSCRUDE KSCRUDE is offline
KSCRUDE is starting off with a positive reputation.
Quote:
Originally Posted by dwh039 View Post
Everytime I start my 2011 f250 6.2, with ambient temperature at -30 or colder. I get an extremely rough idle for roughly 10 to 30 seconds in length. Sounds like it is running on only 4 cylinders, then you I will hear a popping noise and it idles normally after that. My guess is an exhaust restriction of some sort, maybe egr valve related. It never throws a code during or after the rough idle. Also doesn't matter if its plugged in or not. Any ideas? Also truck has 100k miles on it.
Omg, will it start at -30 when not plugged in. If Its that cold, I don't even want to get out of bed. Global warming my ars.
Rough idle when started (when engine is hot)? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 2 09-05-2015 02:37 PM
6.0L Rough Idle on Cold Start rockford04 6.0L Power Stroke Diesel 3 11-15-2010 09:38 AM
Rough idle davewave649 1961 - 1966 F-100 & Larger F-Series Trucks 4 01-21-2010 12:11 AM
2005 ranger 3.0 rough idle gfsdude 3.0L V6 1 03-31-2009 03:39 PM
2003 Windstar-rough idle when at a stop in drive. ryzl30 Arizona Chapter 2 01-28-2008 02:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
