no crank no start help tried everything - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-10-2014, 02:23 AM
Grady Whitman Grady Whitman is offline
Grady Whitman is starting off with a positive reputation.
Exclamation no crank no start help tried everything
i cant really post on the forum cant find my problem anywhere its a 2000 expedition 5.4L i replaced the battery, the starter, and the solenoid, i can turn the engine over by hand, and when i turn the key the starter clanks against the flywheel but wont turn over all the fuses are good and im completely out of idea's it started one day then bam hasn't cranked in 2 months
Old 02-10-2014, 07:10 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Test the battery and starter cables for excessive voltage drop when under load.
Old 02-10-2014, 09:30 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Follow the negative cable from the battery to the engine block and make sure it is tight.
Old 02-15-2014, 01:15 PM
pat49 pat49 is offline
pat49 is starting off with a positive reputation.
no start
Check connections on positive and negative battery cables at battery, block and starter. Test voltage across battery terminals when trying to start
if it stays above 10 volts check it at the starter between the positive
cable terminal and a clean ground like the starter case or the block.
If it's 10 volts or greater suspect the starter if not it could be the battery.
Try jumpers or charge the battery.
Warm start issues BlueOx460 1987 - 1996 F150 & Larger F-Series Trucks 2 08-10-2016 08:04 PM
Starter solenoid? Checking starter? mOROTBREATH 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 09-24-2013 07:01 PM
Truck wont turn over or start Phlanx 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-07-2013 10:53 AM
68 f100 390 starter troubles codafisler 1967 - 1972 F-100 & Larger F-Series Trucks 5 12-25-2011 03:22 AM
HPOP Drains down instantly after refill & crank PLUS (no start with key) JACKA$$ 1999 - 2003 7.3L Power Stroke Diesel 19 04-25-2010 03:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
