Gearing - Ford Truck Enthusiasts Forums
Gearing
Old 02-10-2014, 02:16 AM
Old_blu_f150's Avatar
Old_blu_f150 Old_blu_f150 is offline
Old_blu_f150 is starting off with a positive reputation.
Gearing
So first off I know this is a stupid question and I know I can search it but just wanna get some feedback from y'all so here we go
1. What's gears are in my truck now I got a f150 4.9l EFI 4x4 with the 8.8 in the rear I can't read the tag on the diff cause it beyond rusted and coated in god only knows what
2. I plan on lifted it and putting 37's up under it and wanna know the best gear ratio I should run for them to get alright gas mileage cause I know I ain't gonna get the best and good to go wheeling cause it my daily and my toy
Thanks and again I'm sorry I know I could search all this but I just wanna get some feedback and thoughts from y'all
Old 02-10-2014, 02:21 AM
oldford65 oldford65 is offline
oldford65 is starting off with a positive reputation.
cant really help on the best gear. But if your pretty sure your truck is all original. Just check the door tag. And check up on that code. I know my 2wd 4.9 C6 is a 2.73 i believe
Old 02-10-2014, 02:28 AM
Yeah I just did the vin search on the ford website but it doesn't say anything about the gearing and the tag in the door doesn't say anything about the gearing either
Old 02-10-2014, 02:30 AM
And yes my truck is allllll original it was my grandpas that got passed down to me and I'm the only person that has ever worked on it
Old 02-10-2014, 02:31 AM
on mine its lamenated on the cab at the stricker. It tells all the info on the towing compacity and tire size and such
Old 02-10-2014, 02:34 AM
Yeah mine is to but it just says tire size and what psi to run haha it doesn't say anything about towing
Old 02-10-2014, 02:45 AM
ok someone will come along with more experience. should be a tag with the codes trim,axel, and so on. only other way is to jack it up and turn the wheel and count the drive shaft revolutions
Old 02-10-2014, 02:51 AM
Yeah on the bottom of the tag it says axle but all it says under it 1Q whatever that means haha
Old 02-10-2014, 02:54 AM
are you sure its not 19? 3.55
Old 02-10-2014, 02:55 AM
Old 02-10-2014, 02:57 AM
Ok it is a 19 the bottom of the 9 isn't all the way there sorry bout that and thanks all at the sometime hahaha so I got 3.55 right now then
Old 02-10-2014, 03:05 AM
cool. As far as I know that is a good set. But others who 4 wheel and play will have better ideas if there is any.
Old 02-10-2014, 03:21 AM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
3.55's with 37's would be TERRIBLE. But thats not all. The TTB front axle simply cannot handle 37's. Don't let anyone tell you otherwise. I had 35's on mine and it ate balljoints, universals and could not stay aligned for more than 500 miles. And with 37's, there shouldn't be any discussion of fuel mileage other than it will suck. You are going to have to solid axle swap with a 6" lift and 4.56, possibly 4.88, gears as well as simply putting fuel economy out of your mind to have a reliable offroad toy that could be driven when your done wheeling. Your best bet for an offroad toy with 37's is a Dana 60, Sterling 10.25 swap, which will likely require a donor truck.
Old 02-10-2014, 06:40 AM
FuglyF100's Avatar
FuglyF100 FuglyF100 is offline
FuglyF100 is starting off with a positive reputation.
Quote:
Anything larger than a 31" tire will suck with 3.55 gears. I just bought my '94 a few weeks ago and it has 3.55's and had 33" tires on it when I got it and even the 33's were too big for that ratio. Really, with these TTB front setups, if you want to go any bigger than stock, you might as well do a solid axle swap because otherwise you will eat ball-joints and bushings like a fat kid eats cake...
Old 02-10-2014, 07:55 AM
Nothing Special's Avatar
Nothing Special Nothing Special is online now
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Quote:
"Suck" is not a very quantifiable term. What sucks for some people might be fine for others. Also engine and trans both make a huge difference.
I had 3.55s and 33" tires on my '95 F-150 with a 351 and E4OD. That combo worked great for me. I hauled 11,000 lb loads (total including the weight of the truck) in the Rockies with that setup and was perfectly satisfied with it. It certainly wasn't as fast as it would have been with 4.10s, or a 460. But for me that was the right setup.
Post up a pic of what your truck looks like TODAY! 73FordF100 1973 - 1979 F-100 & Larger F-Series Trucks 2164 Today 05:02 PM
What brand Cam Phaser to buy? Tmad 2004 - 2008 F150 2 04-27-2016 10:13 AM
351W Carb Conversion ? 90' XLT 1987 - 1996 F150 & Larger F-Series Trucks 19 10-08-2015 10:31 AM
M5OD problems 85F350IDI 1987 - 1996 F150 & Larger F-Series Trucks 6 01-26-2015 10:03 AM
73 f100 custom acfd813 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-23-2014 09:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
