Been trolling the sight now for a bit and have seen the terms "High Boy" and "Low Boy" used to describe some trucks. Yet I am clueless as to what the difference is. Could someone please throw me a bone as to what makes them unique from one another.
Thanks in advance.
A "highboy" refers to a 73-77.5 f250 4x4, where as a "lowboy" refers to the 77.5-79 f250 4x4's. the highboys from the factory actually sit roughly 4 inches higher then the later model f250's. hence the term. Other differences in include 2.5" inch front springs that are mounted to a crossmember in the front of the frame, low pinion front big hub front axles, and divorced transfer cases.
Thanks in advance.
C7TZ-5560-F6 leaf rear spring standard equipment, C7TZ-5560-G9 leaf rear spring optional. C9TZ-5588-A single (1) leaf auxillary spring optional for both.
