Pitman arm on 1/4 inch less on new steering box - Ford Truck Enthusiasts Forums
Old 02-09-2014, 08:17 PM
balingwire balingwire is offline
balingwire is starting off with a positive reputation.
A buddy and I installed a Red Head steering box on my '78 F-150, and the pitman arm doesn't slip on as far as it did on the stock box, about 1/4 inch less, with the shaft nut tight. The arm is now probably 3/8 inch from the bottom of the box, and you can see the top of the splines on the shaft. The nut is fully threaded on, but there are not threads sticking out - is that ok? I don't like it bc that's not how it fit on the other, but if I'm assured that it's ok, then I'm ok. Thank you.
Old 02-10-2014, 12:36 AM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Here's a picture of mine, fits about like OEM box did. This is a '78/79 style pittman arm on my '77 Red Head box (same box '76-'79 on F-150), I swapped over linkage in 1986 but just put RH box on Dec 2012. There is a wide space at 4 places around the shaft and a double wide spline in the pittman arm that must locate there (or vice versa?).
Old 02-10-2014, 05:48 AM
EricJ EricJ is offline
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
I was going to guess not aligned with the keyways as well. If you torqued it down and it' is not aligned properly you may have hurt the spline, so look it over real good if that is the case before you put it back together.
Old 02-10-2014, 07:40 AM
hickory1991 hickory1991 is online now
hickory1991 is gaining momentum as a positive member of FTE.
I suggest calling Redhead to see what they say. From everything I have read about them they will gladly advise you on this situation.
Old 02-10-2014, 09:56 AM
Quote:
This makes me feel better - this is exactly how mine looks. I'll check with Red Head and see what they say, too.
Old 02-10-2014, 09:04 PM
tbear853's Avatar
That one above in my pic is correctly installed, there really are only 4 directions that the pittman arm will go up on the shaft far enough to let you thread the nut with washer, and of those 4, only one works when mounted on the truck. You can't put it on with the arm towards rear or right or left, the steering box shaft does not go 90 degrees right or left either. If you miss the wide spline with the wide slot, it simply will not go on far enough to let you put the nut on behind a washer.
If it looks like that one picture .... just torque it now .... 'cause it's right!
Steering box question. Stumped! catzr440 1999 to 2016 Super Duty 6 10-19-2016 02:03 PM
Toyota box pitman shaft fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-15-2015 10:36 PM
Steering box/pitman arm question vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 6 05-16-2013 01:28 PM
Sector Shaft 7.3 Ex 1999 to 2016 Super Duty 2 10-24-2007 05:05 PM
Pitman Arm nut size? 01f350 1999 to 2016 Super Duty 1 03-23-2007 10:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
