Correct Michelin tire pressure? - Ford Truck Enthusiasts Forums
Old 02-09-2014, 04:38 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat Big-Red-Lariat is offline
Big-Red-Lariat is starting off with a positive reputation.
Just changed from Pirelli Scorpions to Michelin LTX M/S2's and not sure of correct tire pressure. Anybody running these?
On the Pirellis I was using 40lbs most of the time and 44lbs with a heavy load and towing.
Same for Michelins?
Old 02-09-2014, 06:41 PM
marcortez marcortez is offline
marcortez is starting off with a positive reputation.
Hello
I have found everything I ever wanted to know using the TIRERACK link at the top of every page here.
For a P275/65/R18 in the model LTX M/S2 you're considering, the TIRERACK site says max load 2601# and 44# max inflation pressure.
Old 02-09-2014, 07:04 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Same for Michelins?
Tire pressure is a function of load to be carried and the tire size, of course limited to the maximums of the particular load range. Brand has nothing to do with it; if the tire size is the same then the pressures would also be the same.
Old 02-09-2014, 07:13 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Same for Michelins?
275/55/20?
I ran between 36-38lbs in my 2006 SCrew FX4 unloaded. Weighed about 6050lbs unloaded. Those were 275/60/20 P-rated LTX M/S2s with damn near the same loading you're speaking of. I hope that helps.
Old 02-09-2014, 08:31 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
I run the same tire at 40PSI. My truck is a fair bit heavier than stock, with a replacement front end, commercial topper, and several hundred pounds of equipment on board. They seem to wear fairly evenly (I'm on set #3 at 138K).
Old 02-10-2014, 04:33 AM
yes 275 55 20s. Will try 38-40lbs for starters. Thanks for the advice!
Old 02-10-2014, 06:06 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
I always run my P rated tires at 38, this seems to be the sweet spot for even wear and gives a few pounds adjustment for temperature changes. I read years ago, this may have changed by now, that P rated tires reach their full load carrying potential at 35 PSI, the rest of the adjustment up to 44 PSI is for sidewall flex.....the footprint, if you will.
Edited to add: Originally I heard the above information when I emailed Nitto about the max pressure being 35 PSI on my new Terra Grapplers that I had installed on my old Dodge truck. I was concerned because any other passenger rated tire I owned to that point had a max inflation pressure of 44 PSI. Their reply in a nutshell, was that a P rated tires max load potential was reached at 35 PSI and the rest other 9 PSI was just foo foo (not verbatim obviously). A quick Google search lead me to Tire Racks tire tech page that basically confirmed this:
http://www.tirerack.com/tires/tirete...jsp?techid=196
http://www.tirerack.com/tires/tirete....jsp?techid=21
Tire Pressure on the OEM Michelin's Ocean's 2015+ F150 5 06-04-2016 10:53 PM
Back to Back (to Back) Tire Test johnkn 2015 + Expedition & Navigator 7 01-14-2016 08:23 PM
Back to Back (to Back) Tire Test johnkn 2007 - 2014 Expedition & Navigator 0 12-03-2015 02:22 PM
Michelin Tire Recall econolinemanor 1968-2013 Full Size Vans 3 08-30-2015 12:34 PM
What Tires!! jrciii56 2009 - 2014 F150 20 09-21-2010 04:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
