Any Mechanics Out there? - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
Old 02-09-2014, 02:42 PM
gwcon's Avatar
gwcon gwcon is offline
gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.
Replacing the oil in my wife's 2012 Explorer with the V6 today. Checked the air filter and there is oil residue,enough to wipe out with a rag, in the air intake. Filter is clean but the bottom of the intake housing coated with oil. Can anyone tell my what that would be from? I have a feeling it can't be good. Thanks.
Old 07-15-2014, 08:58 AM
BoKnowsDiesel BoKnowsDiesel is offline
Former Vendor
BoKnowsDiesel is gaining momentum as a positive member of FTE.
That's normal for that Explorer, something in the PCV design makes it do that. Had one like that when I was working in the dealership, showed one of the other techs, and that's what he said.
Old 07-15-2014, 09:29 AM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
PCV valve controls crankcase pressure, make sure all the vacuum line are on and valve is working, dont overfill the oil, midrange on the stick is good, and if you have any concerns bring it back to the dealer if you have the warranty
Old 07-15-2014, 01:29 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
replace the left (front) valve cover. Theres a ssm on it.
Old 07-16-2014, 05:31 AM
gwcon's Avatar
I never updated this thread because I never had any responses. I knew a small amount of oil was normal but when I saw this back in Feb there was a lot of oil. It turned out to be a bad PCV valve. Dealer replaced it under warranty.
Old 07-16-2014, 05:58 AM
David7.3's Avatar
Where is the beer?
Good news glad to help!
Cold Air Intake Oil vs. Paper Filter? 1L243 1999 - 2003 7.3L Power Stroke Diesel 3 02-15-2016 02:42 PM
oil leak from dip stick tube to pan DDPJ 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-01-2015 11:56 PM
2011 Ford Explorer Limited sd4363 2011 & Newer Explorer 2 07-01-2015 03:10 PM
High pressure oil problem. mr.speaker 6.0L Power Stroke Diesel 16 05-08-2015 04:54 PM
2011 Ford Explorer sd4363 Oil & Lubrication 2 11-04-2014 01:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
