292 1963 f100 won't turn over - Ford Truck Enthusiasts Forums
Old 02-09-2014, 09:11 AM
sre8212's Avatar
sre8212 sre8212 is offline
sre8212 is starting off with a positive reputation.
So after several months I've got my 63 f100 with the original 292 running (new main rear seal, water pump - thanks to the forum's help in identifying the part number, radiator, oil pump, fuel pump and more ) After about 100 miles or so it's stopped turning over. Tried jumping it, tried even swapping the battery but sounds exactly the same. Lights work. So I'm thinking starter? Any other ideas. Appreciate any advice. This did happen after driving it at night for the first time and using the headlights - maybe that's related but again the two year old battery seems just fine.
Old 02-09-2014, 10:46 AM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Have you tried bypassing the solenoid? Could be bad...
Old 02-09-2014, 05:54 PM
sre8212's Avatar
Quote:
Thanks for the fast reply! Have not tried that yet but I know. should. The engine does try to turn over so you're right maybe the stater is okay but not the solenoid. Do you have a simple step by step for doing that?
Old 02-10-2014, 09:47 AM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Quote:
Try a light whack with a rubber hammer. Yes, Ford techs at a Ford dealership do this. You'll still need a starter solenoid, but you may scare it into working. If it still don't work, use a jumper wire or a screwdriver from the + battery terminal to the S terminal on the solenoid.
These things are cheap and have a rep for failing. I always carry a spare when I'm driving an older Ford. I mean, c,mon, less than ten bucks
Old 02-11-2014, 09:43 PM
sre8212's Avatar
Thanks for the advice. Bypassed the Solenoid and same thing - starter tries to crank the engine but doesn't get there. Thinking distributor/plugs.
Old 02-11-2014, 10:17 PM
vntgtrk's Avatar
It looks like it's time to pull the starter and take it to an auto parts store for testing. Troubleshooting is a process of elimination. If the starter checks out, and I have my doubts, then it's time to think about possibly timing. BTW have you put a socket on your crank bolt and tried turning the engine by hand?
Old 02-12-2014, 01:55 AM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
How cold is it where you are at? Truck parked outside in the snow and salt brine muck? Sometimes rebuild starters aren't too good. They will work OK, just not for very long. Or when it gets esp. cold. Some years back I had to took a propane torch to the starter and thaw it out, got my truck out of the parking lot the next day anyway. It was well below 0. I did not want to replace a starter outside and figured it might loosen up some and get the truck home.
That replacement has held up pretty good since then but taking no chances I recently bought a new one from DB electrical, and a new bendix, solenoid, it's all ready to go. If it ever warms up in the garage. The problem with starters they can be bit or miss. Try to breakdown at home if ya can.
Old 04-19-2014, 07:37 AM
sre8212's Avatar
Solved!
So after all that, the obvious. Either bad fuel gauge or sender unit, float. Truck was out of gas . Running great!
Old 04-19-2014, 08:29 AM
vntgtrk's Avatar
I've never had that happen. And I hope it doesn't happen again
Old 05-10-2014, 08:35 AM
sre8212's Avatar
63 dies at idle Combatwombat 1961 - 1963 F100 Unibody 7 08-05-2015 02:01 PM
Randomly shuts off Combatwombat 1961 - 1966 F-100 & Larger F-Series Trucks 0 08-01-2015 04:31 PM
Battery size newguy399 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-18-2015 11:53 PM
Bellhousing question 8lugthug 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-27-2014 09:40 PM
Water Pump ID Smokey1961 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-17-2007 08:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
