57 312 Y Block rear main seal
Old 02-08-2014, 09:03 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
My friend had the seal replaced in his 57 T-Bird 312
He says the instructions say to install the seal offset'
His mechanic installed it 1/2 up and 1/2 down.
It is now leaking more than before, does this sound logical?
The original seal was "rope"and the new one is "rubber made by "Best Gaskets"
This is in a 56 F100. I'm not getting an answer on the Y block forum so I thought I would try you guys.
Old 02-08-2014, 09:11 PM
JEREED's Avatar
JEREED
JEREED is offline
the rubber seal does need to be installed "offset".he could have nicked it when installing,may even have to original rope put back in it.
Old 02-08-2014, 11:00 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Yes it does need to be offset and the little side seals need to be installed carefully and be a little proud so they seal against the pan. That is the way I installed mine a couple years ago, doesn't leak after 6000 miles.
Old 02-09-2014, 12:24 AM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
Great info both of you, I'll print out the diagram and give it to him. His mech said he would do again for free, and though he's done hundreds of them he has never done a Y block before.
Old 02-09-2014, 06:55 AM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
It may not be the seal around the crank that's leaking, it might be the two side pieces with the headless nails that seal the main cap to the block.
Old 02-09-2014, 10:04 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
6336 = Seal-Crankshaft Rear Main Bearing Cap.
6701 = Packing-Crankshaft Rear (rear main seal).
Old 02-09-2014, 02:18 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
Tks for all the replies, I'm getting too much info for me to pass on accurately, so I have convinced my friend Mike to log in to this site and register! I hope he follows through.
Race4Fun82
09-19-2006 09:22 AM
Race4Fun82
08-05-2006 05:41 PM
Midnite Cruiser
11-28-2005 07:53 AM
a9464
07-24-2003 08:08 AM
pcmenten
06-11-2002 06:33 PM
Quick Reply: 57 312 Y Block rear main seal
