Where is my small leak
My '03 F350 6.0 has a small leak. I was under the hood/truck for over an 2 hours this evening and can not find it. I drove it for a half hour, so it was under pressure and to temp. We are talking maybe a quart a month. But there is drops in the snow none the less. I know its from the lower half of the motor and the drops are almost center, up front. There is a netting on the lower rad hose that's soaked. The sway bar is covered but I think its from the wind of driving. All upper hoses I can see/feel are dry.
It could be at the spot where the lower radiator hose bends to go around the steering box. It should have a plastic protector piece on it, but if it came off or moved out of place then the hose can rub on the steering box and cause a pin hole leak!
Just ask me how I know
And that lower hose is not cheap!!!
yikes! I just realized GREEN coolant?? shouldn't be using green coolant in the 6.0... only the Gold Motorcraft.
I had the Ford dealership where I bought it put all new fluid in. That's what they put in so I figured it was ok by Ford.
The reason is they let you Jr. Yard boy/girl do the fluid change and they can
make a mistake.
If it was just out of the shop I would go back and have then make sure it is
the approved coolant for the year and engine. If they put the wrong stuff init
then they need to drain,flush,flush,flush,flush some more then fill with the
right stuff.
Sean
