6.0 Tach Signal - Ford Truck Enthusiasts Forums
6.0 Tach Signal
Old 02-08-2014, 03:18 PM
Claybreaker144 Claybreaker144 is offline
Claybreaker144 is starting off with a positive reputation.
6.0 Tach Signal
On my cummins swap I am going to machine slots in the edge of the water pump pulley to generate the necessary 58 pulses per engine RPM. I can't use the Destroked kit because I am using a 2007 harmonic balancer and the OD is too large for the tone ring. The Destroked sensor will work but it might be a little bulky and it doesn't look like they sell the sensor as a stand alone part. I talked to a supplier to my work about a prox sensor and he wanted to know if it is NO or NC and also if the sensor is a NPN or PNP? Anybody know the answers? How about the cummins or ford sensors will they work? I have looked closely at the 6.0 motor out of my truck and see no crank or cam sensors where are they located?
Thanks
Old 02-13-2014, 08:30 PM
67 Views and nobody can say where the 6.0 crank or cams sensors are? I better move this one to the SD forum.
Old 02-13-2014, 08:36 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
The crank sensor is on the right side of the motor towards the front. The cam sensor is on the left side behind the lower radiator house outlet.
Sent from my Telegraph using IB AutoGroup
Old 02-14-2014, 06:57 AM
Thanks Chris
Destroked 6.4 PS to a Cummins uh60 General Diesel Discussion 0 12-04-2016 11:45 AM
Destroked vs. Diesel Conversion k_brenner 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-11-2013 07:59 PM
tach 99 f350 cummins 12v deck60 Engine Swaps 13 05-02-2012 03:41 PM
Destroked 12vexcursion Excursion - King of SUVs 19 07-10-2009 06:14 PM
NP435 and ZF interchangibility josh78910 Clutch, Transmission, Differential, Axle & Transfer Case 4 05-01-2007 10:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
