How fast can you go in 4wd?
Spent 6 1/2 hours yesterday driving back from my job to home in a snow storm. Conditions weren't too bad when it was solid snow floor the sections that had been plowed and had a 50/50 mix of packed snow and bare pavement were a little sketchy. It was my first drive in snow out side of driving around town since buying this truck. I spent most of the drive in 4 auto and in some spots switched to 4 high. When I was looking over the manual, I didn't see anything about maximum speed while in 4 wheel drive. I kept it under 50 the entire time since that was the cut off in my tundra. What is top speed while 4wd is engaged? another related question, Whats the difference between 4 auto and 4 high?
any speed, you could bounce off the speed limiter in 4x4 all day long.
AUTO 4x4 can be used on ANY road surface including dry road as it does not engage the front until the rear spins.
4x4 HIGH to be used on slippery conditions, it is shift on the fly and has no speed restrictions, even if the manual has something i can testify you can hit triple digits without issue year after year.
I don't know the real answer from a technical perspective but I also think there is no limit. But like you, I tend to not cruise over 50 mph because,
- That is how I was taught from a young age.
- It is my natural comfort limit if roads are packed with snow to the point I want 4WD constantly.
- I will speed up to pass somebody. It's not a rule I can't break.
In a 2wd truck, the engine puts power into the transmission, and that powers the driveshaft.
In a 4wd truck, the engine puts power into the transmission, which puts power into a transfer case. From there it powers the rear drive shaft all the
time. The front drive shaft, which is also powered by the
transfer case, is engaged only if you put it into 4wd.
This has been done with gears or chain drive, so both driveshafts are
"geared" together and turning at the same speed, with no slippage.
This causes a problem when a wheel wants to go at a different speed, like when you're turning, and you're not on a surface, like snow, that allows slippage.
I've had 4 4x4 trucks, and this is the only one without a published speed limit.
AWD doesn't use this "geared" function of the transfer case; it uses a separate function involving clutches.
In the AWD, or AUTO mode, if you have such a transfer case installed,
driving in AUTO is actually RWD, but the clutches put a bit of pressure
on the front drive shaft. If rear wheel slippage is detected, the clutches engage fully in a nano second, and now your front drive shaft is powered.
I guess it only stays engaged until the slippage problem ends.
I've used mine a lot in the winter, and can tell no difference using it, or
putting it into 4wd. However, if I feel I needed to be in 4wd all the time, I'd select that. The "Old School" attitude as some of you put it.
Some AWD cars operate this same way.
As opposed to Suburu, Audi and others, that power both driveshafts
all the time. And that's my long winded answer to a short question.
I drive as fast as conditions allow. 4WD or not, if I need to be in 4WD to begin with I'm not going to be racing like the INDY 500. Thing to remember is that drive train is great for starting and keeping traction but not for stopping. Sue me for the PSA but thats my $.02
Annoys me to no end people that go out racing around thinking they are invincible because there is a 4x4 sticker on the side of their vehicle. I know that a percentage of people know how to drive in the snow(would count most of you all, especially alaskan who has to live in it most of the year LOL) but there is a greater percentage of the random joe that don't (look in the ditches to find them lol). I like my family and I still living/breathing. End rant LOL
But to answer your question there is no limit/cuttoff technically as the others have said on these trucks. Its as fast as you can keep it on the road.
Agree'd! thats why i have studded snow tires on 6 months out of the year helps greatly in the turning and stopping and general traction department! biggest thing is paying attention to road conditions, other drivers and your own actions.
i saw that i get crap on the forums for driving fast but i've never (knock on wood) been in a ditch or lost it in the winter (i have had some issues with keeping the corvette well handled but thats more a horsepower issue). you get a pretty good feeling of traction when your on ice half the year and you know where the line is and when you cross it.
