'94 SRS light is blinking, and other issues!
Bought a '94 F-150 today. Saw the SRS light blinking. Didn't realize it was for the air bag system until I got home and started reading the owners manual.
Any ideas?
Also, the horn does not work, and the overdrive lockout button does nothing. Without getting under the dash, I'm wondering if something in the steering column could be causing this.
We're expecting snow tonight, so it might be a few days before I can start working on the truck. I'll start by checking every fuse in the truck, and going from there.
I was reading in the Haynes manual that if I want to remove the air bag from the steering wheel, I need to take it to the dealer. I don't plan to do that. I'll disconnect the battery, of course, before I do anything, unless you guys tell me otherwise.
Other than the above, the 300 six with fuel injection runs good, and is strong. The electronic AOD transmission shifts smooth. Its 4 wheel drive, and the transfer case is smooth and everything is working.
Owning a ford truck again... the front tank gas gauge does not work. Typical Ford. My old 1983 truck had this problem, and I learned to live with it.
Any ideas?
Thanks for your fast reply!!!
EDIT: Ford is very proud of this clockspring. I'm finding DORMAN units on ebay. Are they any good?
TBH I lived with mine blinking 32 from a month or two after I bought it to the day I rolled the truck. That was just short of 18 years. I don't have any data about which is better -- but the OEM did fail with less than 2500 miles on it, because I bought the truck new and it failed not too long after I drove it off the lot.
Simply experimental data -- sample size of one. Use with all due caution.
Dorman part # 525-200. Looks like O'Reilly and Auto Zone are the cheapest I can find at $49.99 each. Even Amazon and Rock Auto are more expensive.
http://www.oreillyauto.com/site/c/de...OE0/525200.oap
http://www.autozone.com/autozone/par...er=688211_0_0_
Thanks for all the help on this.
One other question: I can't find the OEM horn(s) on this truck. On my '83 and 84 trucks, it was on the drivers side by the radiator. Am I just not seeing it?
You should hear this silly little horn someone installed here. It's got a hot wire connected directly to the battery. I'm getting rid of that, fast.
magnumea
07-01-2011 11:21 PM
SupraMan1990
11-11-2006 10:32 PM
david b
05-08-2001 06:30 PM
