E350 wont fire - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
E350 wont fire
Old 02-07-2014, 09:28 AM
Tnash542 Tnash542 is offline
Tnash542 is starting off with a positive reputation.
E350 wont fire
Hi everyone. I have 1994 e350 460 7.5 auto it's a c class motor home. It lost fire .here what did so far.
1 checked for spark with spark plug tester
2 took the ice to the part store it passed.
3 replaced the pick up in the dist,
4 replaced coil
The only test that does pass is the coil wire test for the neg side.
To test the wire you are suppose to use test light put clip on pos side of the battery . Touch the neg wire on coil. And it should flash on and off.
When you turn the key the test light goes dim. And doesn't flash.
But when you unplug the harness from the coil it stays bright but still doesn't flash I'm lost.
Old 02-07-2014, 10:25 PM
ceetwarrior's Avatar
ceetwarrior ceetwarrior is offline
ceetwarrior is gaining momentum as a positive member of FTE.
No spark? Check the TFI module.
Lost spark jonesg 1968-2013 Full Size Vans 2 06-08-2015 07:08 AM
1985 e350 4x4 no spark.. Gordesky Mco 1968-2013 Full Size Vans 3 08-10-2014 05:32 PM
Will Crank, No Start, Everything Tests good Acidic 1987 - 1996 F150 & Larger F-Series Trucks 22 02-21-2014 01:10 AM
Here are my test results. PCM bad or not? Klau 1997 - 2003 F150 10 12-07-2013 03:45 PM
1979 F150 no spark except... Ol yeller Ford 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-05-2013 07:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
