56 F100 Running board clearance - Ford Truck Enthusiasts Forums
Old 02-07-2014, 09:19 AM
perks56's Avatar
perks56 perks56 is offline
perks56 is starting off with a positive reputation.
What clearance do you have between the top edge of your running board and the cab bottom?
I originally had mine mounted on the support brackets with a spacer between the running board and bracket to raise them for better alignment to the rear fender and thus levelling them out. Fender bolt holes were all ready punched in the new box side panels and the fenders are mounted as far down as I can get them.
I have the 3 inch wider fenders with the notch for the running board to sit in and they would have been down in the notch by at least 1 inch if i went direct onto the brackets.
Only problem is that I think that I am to close to cab because every once in a while the cab will hit the running board edge when the cab flexes with the frame i believe.
Thank you, Kevin
Old 02-07-2014, 09:51 AM
emay's Avatar
emay emay is offline
emay has a good reputation on FTE.emay has a good reputation on FTE.
This is my 53 and the focal point was the wheel/fender in this shot but you can see the spacing under cab to board. These are the mid fifty 3" wider fenders, measure an 1-1/4" from top of board to cab seam. Mine fit tightly in the notch.
Old 02-07-2014, 12:22 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Sounds like your rear cab mounts are shot, check the rubber inserts.
Running Board Fitment EFranzen 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-20-2017 11:51 AM
Step Plates Rusted56 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 06-13-2016 06:44 AM
1948-1952 Running board length Mr. Ed 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-26-2016 01:34 PM
55 running board hassle CdnWillyG 1948 - 1956 F1, F100 & Larger F-Series Trucks 37 04-12-2015 04:29 PM
Running board questions Project-55 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-01-2014 09:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
