5.4L, CNG to gasoline - Ford Truck Enthusiasts Forums
Old 02-07-2014, 05:40 AM
raven3 raven3 is offline
raven3 is gaining momentum as a positive member of FTE.
Have a 2000, 5.4L that is powered with CNG, stock setup.
Want to convert to gasoline powered engine.
Both CNG & Gasoline powered engines have identical stock CR.
Want parts would be required for this conversion?
Most popular conversion is gasoline to CNG.
Old 02-07-2014, 02:55 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
PCM, Gas tank. Wiring harness, intake manifold, fuel injectors, air intake. A donor truck would be your best bet.
Old 02-07-2014, 03:03 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
If it is running correctly, sell it and buy a gas rig. JMO. You'll be on the road in minutes and if you have to buy a donor rig anyway, you may end up money ahead or even. Plus, your time on earth is limited, why spend it on this?
Good luck with it.
Old 02-12-2014, 12:29 AM
Thank you for the input.
Probably will part it out rather than convert from CNG to gasoline.
Only problem is steel coolant heater line that runs under the intake manifold, leaks.
Understand this a common problem.
Ford van Econoline E series CNG all parts free swap for gasoline parts, (Expedition, F150?) GreenMM Ford Truck Parts for Sale 13 01-07-2017 09:49 AM
I would like to convert my 1998 e250 CNG factory 5.4L engine BACK to gasoline!! GreenMM 1968-2013 Full Size Vans 61 10-30-2016 11:09 PM
Technical Engine Question. I NEED Your Advice!! Streamliner 2009 - 2014 F150 6 11-14-2012 12:39 PM
99 e250 ford cng jbakers1 Alternative Fuels, Hybrids & Mileage 4 09-10-2012 04:08 PM
CNG F 350 7.5 DRW J-Martinez Alternative Fuels, Hybrids & Mileage 23 06-06-2012 09:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
