brake controller - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
brake controller
Old 02-06-2014, 11:18 PM
nadieselbogger85 nadieselbogger85 is offline
nadieselbogger85 is starting off with a positive reputation.
brake controller
Question here . I have a 2014 f250 and was looking at a brake controller and a oem in dash controller that goes beside the uplifted switches are around 250 bucks my question is if I get one of the aftermarket ones from u haul or wherever will it work with the truck being all the new electronics and sensors in these trucks
Old 02-07-2014, 04:51 PM
BossGasser BossGasser is offline
BossGasser is gaining momentum as a positive member of FTE.BossGasser is gaining momentum as a positive member of FTE.
I suggest that you get the OEM unit.
I added an AM unit in the Ranger I had and it worked very well. However, it was awkward to see and use.
I had an OEM added in the 2011 F150 I had and it was easy to use and see.
I ordered my truck with the controller this time. Easy to use, see and it works very well.
Old 02-07-2014, 05:18 PM
Hotrod70d's Avatar
Hotrod70d Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
aftermarkets will work fine and are cheaper . i think oem will work better with the tow haul mode because the computer will reconize a trailer is hooked to the truck. plus the install is easier and cleaner.
Old 02-08-2014, 09:12 PM
Yes that's what i was thinking also somehow i over looked it not having one when i bought it or i would have made them throw it in deal guess il have to keep an eye out for a good deal on one
Old 02-11-2014, 09:26 AM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
The oem one will apply trailer brakes faster than you can manually apply the brakes when you get hit by a big gust of wind and get out of control.
I had this happen with my 2010 f150 and the truck applied the tt brakes faster then I could grab them and I was ready for the gust when I hit the clearing and was only doing 50mph, when 60+ mph cross winds jackknifed me, tt brakes pulled me straight. Had this happed a couple times that trip and would never been able to stay on the road otherwise, would have lost 2 days travel waiting for the winds to slow. I also had traction control, I don't think aftermarket break controlers will work this way.
Integrated Brake Controller weak? vectrex Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 21 06-19-2014 12:52 PM
2006 F250 Brake Controller brenthottle 1999 to 2016 Super Duty 1 07-07-2013 02:27 AM
Integrated Brake Controller vs. Add On ItsABeautClark 1999 to 2016 Super Duty 26 08-19-2010 06:09 PM
Factory TBC and electric over hydraulic brakes powerstroke72 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 10-25-2008 11:23 AM
Question about wiring brake controller. Sycostang67 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 02-02-2004 04:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
