911 degel damage
911 degel damage
I have a friend with a 05 f250 w/ 150k on it. He bought some low grade fuel, thought he was gelling up and put 2 large jugs of 911 in it. He then took it to the dealership and they installed a new set of fuel filters, upon my inspection the secondary filter has 2 tears in it. They also Told him it needed 4 injectors. Now I have it sitting in my heated shop and currently have a miss. I have cylinder cont codes for 4 and 5. I am going to drain his tank and get 10 gallons of good fuel and see what happens. Did that much 911 damage all the injectors? It passed the bubble test, ficm voltage and icp/ipr values are looking good. It's pretty much stock except for the stc fitting and egr delete I helped him with last winter. The dealer also installed an oem oil filter on a taller Napa cap. I am not completely confident in the dealers diagnosis after seeing the oil filter and the new torn fuel filter.
Sent from my leash using IB AutoGroup
That's what I thought. When looking at the fuel in the secondary filter it had small pieces of gelled fuel floating around in it. I have a feeling I may be helping with more injectors. I just got my hpo connector on my 03 fixed last night which broke after my injector swap during reassembly.
