Steering Noise - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Steering Noise
Old 02-06-2014, 09:14 PM
Suprawill1's Avatar
Suprawill1 Suprawill1 is offline
Suprawill1 is starting off with a positive reputation.
Steering Noise
Hi All,
Just started getting a creaking noise when I turn the steering wheel. It sounds like it's coming from underneath the vehicle in the area behind the left front wheel. It sounds like rubber against steel and drones as long as I turn the wheel. It also sounds when the suspension is activated. ie when I go over a bump. It's pretty loud.
Any ideas?
Thanks!
Will
'05 Limited
Old 02-07-2014, 06:53 AM
Dan Robertson Dan Robertson is offline
Dan Robertson is starting off with a positive reputation.
Your lower ball joint moves when you steer the wheel. That would be a good place to start. My Ranger pick up squeaked when I turned the steering wheel while sitting still. It ended up being ball joints. Your Escape has MacPherson Struts so it only has lower ball joints. (my 2 wheel drive Ranger has 4 ball joints) A clunking noise at slow speeds is most likely your sway bar links, which is a very common problem and an easy fix.
Old 02-07-2014, 01:35 PM
Suprawill1's Avatar
Thanks for the hit Dan! I'll check out the ball joints.
When I hit a bump, I don't get a clunking sound. It's the same creaking noise that turning the steering wheel makes. It's almost like the sound you make if you wet your finger and slide it across a glass window.
Old 10-11-2014, 03:01 PM
WB4IUY WB4IUY is offline
WB4IUY is starting off with a positive reputation.
Did you find the rumbling noise when you turn the wheel? Mine has the same sound, just started in the last few days. When I'm sitting still, I can turn the steering wheel left & right and hear a "bump bump bump bump".
Dave
Old 10-14-2014, 11:40 AM
FordService's Avatar
FordService FordService is offline
Official Ford Rep
FordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud of
Quote:
Dave
Hi Dave,
I'd recommend getting this in front of your dealership so they can check it out. What's the current mileage on your Escape?
Crystal
Old 10-14-2014, 01:57 PM
Quote:
Originally Posted by FordService View Post
Hi Dave,
Crystal
Hi Crystal,
My 2002 3.0 V6 2WD Escape has about 175,000 miles on it. Been a great truck, and still looks like new. I live in NC and we almost never have any snow/salt here.
Dave
Power Steering Fluid VS Transmission Fluid t24021994 1987 - 1996 F150 & Larger F-Series Trucks 9 05-24-2015 01:50 AM
Creaking noise when wheel is fully turned left MoreBoostPlease Excursion - King of SUVs 9 07-14-2011 05:10 AM
01 f350 power steering noise kdfishe43 1999 - 2003 7.3L Power Stroke Diesel 14 02-15-2010 01:53 PM
Whining when turning Steering wheel. Spirit615 1999 - 2003 7.3L Power Stroke Diesel 4 11-18-2007 06:42 PM
Horrible noise when turning steering wheel orthogod1 1999 - 2003 7.3L Power Stroke Diesel 11 07-12-2007 06:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
