ford 9 inch drum removal - Ford Truck Enthusiasts Forums
Old 02-06-2014, 04:21 PM
filthy6's Avatar
filthy6 filthy6 is offline
filthy6 has a good reputation on FTE.filthy6 has a good reputation on FTE.
After knocking off several inches of cow crap from the differential and axle of my ford 9" I am ready to tackle the drum brake removal. I know how to remove drums but I know that these will be STUCK on. Is 9" removal the same as any others? Any tips on removal when the drums refuse to come off. Also best place to buy replacement brake parts for ford 9"? Thanks
Old 02-06-2014, 04:43 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Drums on the 9" just sit over the studs. Sometimes you'll find tinnerman nuts holding them in place if they've never been removed before, but that's pretty rare these days. If they're present, remove them and throw them away.
What happens many times is the drum will stick to the axle shaft flange from rust, and you'll need to break that loose. Typically, smacking the drum face between the lug studs with a heavy ball peen hammer will knock it free.
Quality Ford brake parts are readily available at any of your better parts stores.
Old 02-06-2014, 04:59 PM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
I had tinnerman nuts on my 56 1/2 ton.But I was going to say I always heat the face of the drum cherry red and walk away.9 times out 10 the drum will pop itself loose in about 45 min cooling.
Old 02-06-2014, 06:40 PM
filthy6's Avatar
thanks Olweldinrig and 52Merc for suggesting my two favorite things banging on stuff and fire. Matt
Old 02-06-2014, 06:43 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
If you can, back the adjusters off first. If the shoes were down to metal and ground a lip on the drum, it is one less thing to fight against. The BFH is always a good choice.
Brake Drum Removal - D60 Rear Blue and White 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-17-2015 05:52 PM
Outline or Tips for Brakes R&R Rear Wheels, '94 F-250 8-Lug justplumducky 1987 - 1996 F150 & Larger F-Series Trucks 7 09-14-2014 09:58 AM
Brake drum removal from 9 inch frb9883 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 02-20-2012 10:28 AM
F-350 DUALLY rear brake drums stuck/rusted? on gary_b Brakes, Steering, Suspension, Tires, & Wheels 0 10-16-2006 07:46 AM
1994 Ford F250 Rea Brake Drum Removal FMG 1987 - 1996 F150 & Larger F-Series Trucks 10 08-16-2006 07:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
