Timing gear question
Old 02-06-2014, 06:06 AM
flatheadkeith's Avatar
flatheadkeith
flatheadkeith is offline
Ok, When I purchased a use crank for my 239 flatty, it came with the timing gear on it. The problem I am having, is that the gear had teeth that went in the opposite direction from the old gear. I didn't notice until I tried to drop it in, that the angle of the gears were opposite, and wouldn't work. I figured I could just pull the old gear off the old crank, and press it on to the new one, but I wanted to make sure that I could. Has anyone had experience with this? Was this crank made to turn the opposite direction? Has anyone heard of a 8BA turning a different direction?
Old 02-06-2014, 07:39 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
It's from an earlier engine, like a 59ab. Used in cars through '48 and trucks through '47. Does it have the distributor drive gear? They all turn in the same direction, unless a rare marine conversion when counter-rotating engines were used in pairs....
Old 02-06-2014, 12:06 PM
flatheadkeith
It is the correct crankshaft. It is an exact match, and the part number is the same. The only difference is the gear.
Old 02-06-2014, 12:55 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Two different V8 crankshaft gears were used in 1948/49 Trucks.
48-6306-A .. Crankshaft Gear-22 left hand helical teeth-Use with camshaft gear having right hand helical teeth.
1935/47 Trucks / 1935/48 Passenger Cars / 1948/49 Trucks.
8BA-6306-A .. Crankshaft Gear-22 right hand helical teeth-Use with camshaft gear having left hand helical teeth.
1948/49 Trucks / 1949/53 Passenger Cars / 1950/53 Trucks.
Old 02-07-2014, 08:02 AM
flatheadkeith
So using the old gear on the new crank shouldn't cause problems, right?
Old 02-07-2014, 08:06 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
That would be correct.
Doomcrew2123
02-16-2016 04:07 PM
Wes(MI)
Large Truck
05-16-2015 03:53 PM
SocialDistortionFan
10-01-2013 12:20 AM
frty7ford
04-15-2011 04:14 AM
scl009
05-07-2010 10:09 AM
Quick Reply: Timing gear question
